Fiat TC operating clearance: valves
Binio
Hi Guy!
It`s my second post in Your forum - at first I say "hallo" and show my car.
I have some question about operational clerance on values - 1.6 TC engine (149C2 or same).
What clearance you propose for this engine, because I have 0,3 IN and 0,35 EX and I have problem with noise from the head, particularly when engine is at high temp.
Thank you for any help.
Salut - Binio
Binio, hi
Set the operating clearance of the valves on the TC at 0.4mm inlet and 0.45mm exhaust.
Your clearances are a bit tight, might make it noisy.
Do the re-shimming operation and see what happens. Check the condition of the cam nose too, it should be round and smooth.
There could be other causes.
Binio
NickRP
If the question was if they have the same length, no they don't, 2.0 items are significantly longer. If you are interested in center-to-center lengths, I could look that up for you. However, I am sure GC has dimensions in head :).Binio wrote:By the way I have another question - that conecting rods in 1.6 TC engine and 2.0 TC thay have themselves size (length) ?
Hope this helps,
Nikola Radenkovic
Binio
Binio
NickRP
Binio
