My Lancia Dedra 2000 Turbo
dzindzan
Post by dzindzan »
Hello, everyone!
I have Lancia Dedra 2000 2l 8v Turbo. I buy it from Germany with engine damage and reconstruct it. This is my modlist:
Home made head porting
Camshaft's from Lancia Dedra atmospheric engine
Adjustable cam pulleys have but still not installed
450cc injectors
3 bar map sensor
Standart fuel pump + 180lph fuel pump
Custom made exhoust manifold
HKS gt2510 ballbearing turbo
Custom made downpipe with screampipe
Custom made free flow exhoust 76mm
Front mount intercooler
Montonni bov
Ecu master2 piggy back ecu installed
NGK b8eg spark plugs
King Dragon air filter
Ceramic cluth kit from Fiat Coupe 2l 16v turbo
Bilstein Yealow shocks with red eibach springs
Stilauto sr500 r17 rims with 205/40 tyres
Boost, fuel pressure, oil pressure, egt, knock gauges installed
Brembo 4 cylinders brakes from Fiat Coupe 20vT have but stil not installed
On dyno at 1 bar pressure 270hp and 360nm, now i will try 1.4-1.5 bar and expect about 300-320hp and 400nm
Some foto's make with phone so sorry from that ;)
samo
Re: My Lancia Dedra 2000 Turbo
Post by samo »
Hello dzindzan,
Your project is very interesting but I have a few questions. First of all I would like to know did you change both inlet and exhaust camshaft or only inlet? Are this dyno graphs figures corrected (crank power) or are they actual figures of the power on the wheels?
I am interested because I am planing a similar setup for my Delta and I was considering fitting a smaller turbo to get better response but I see that you have high top end power but actual torque is lower than original till 3000rpm. I don't understand why.
Limited edition #317
dzindzan
Post by dzindzan »
hi, i have changed inlet and exhaust cams :) this is egnine power not on wheels. Torque on 3000rpm is lower than standart, but on high rpm torque and horsepower are at their peak.
hybrid565
Post by hybrid565 »
Hi Dzindzan,
I noticed that on your specifications that you have a standard fuel pump + a 180 LPH fuel pump added. I presume you installed the fuel pump externally am I right? If so where did you locate it? I have an 8V integrale and I like the power figures that you posted. I too would like to raise the boost a bit more than the 1 bar I have on the car now and adding an additional fuel pump will give me more peace of mind.
Manuel
