Urgent query re Fiat X19/128 cambelt drive pulley
I'm doing a 1300 X19 engine for a client, I think it's got the wrong cambelt drive pulley on the crank nose. To the best of my recollection it should have a flange on the block side, this flangeless one seems to be a TC one. It's ages since I did a SOHC 1300.
Can anyone confirm this? Photo appreciated, and better still if I am right and anyone's got a spare please contact me at
guy.croft@btconnect.com
Thanks very much,
nose pulley (1).JPG (118.78 KiB) Viewed 29586 times
nose pulley (2).JPG (121 KiB) Viewed 29586 times
nose pulley.JPG (110.92 KiB) Viewed 29586 times
simon-spanner
Re: Urgent query re Fiat X19/128 cambelt drive pulley
Post by simon-spanner »
Hi Guy
I cannot recall whether or not my old engine had a flanged bottom pulley- I seem to think not for some reason
cannot check anymore as I sold it to a chap in Wales last year who was going to take it tarmac rallying
Simon
James Bowen
Post by James Bowen »
I do not remember the bottom pulley having a flange. I have checked my Haynes manual, and there is a picture of the bottom pulley wheel and V pulley being put onto the crank. The pulley shown in the picture does not have a flange. The one you have shown appears to to resemble closely the one pictured in the Haynes manual.
I have e-mailed you a link from Matt Brannon's store in the States which has one in stock, and usefully a picture...
Hope this is of assistance. It is impossible to view one properly with the engine in situ.
Regards, James
Thanks Simon, James, and thanks for the mail, James and link to Bayless in the USA - you're right - no flange, which presumably means the cam pulley on that motor should have a rear flange which the listed Piper adjustable cam pulley does not so the belt is going to 'walk'.
I have posted a pic of a MkI Uno Turbo - you can see the rear flanged crank pulley and flangeless cam one.
Does anyone have the flanged pulley from the Uno available?
Thanks, ongoing..
MkI Uno T.JPG (56.82 KiB) Viewed 29506 times
Uros Piperski
Post by Uros Piperski »
I'll try to find one but I think it's 3/4" wide or so, so it can't accept the 1" belt (if needed).
Thanks very much indeed Uros, I will not be using a 1" belt,just standard width,
pastaroni34
Post by pastaroni34 »
FWIW..
The 1300 has no flange, the pulley is the same as the late DOHC engines (late 1756 and 1995cc, 30mm crank nose)
The 1500 pulley isn't as wide and has a flange in the rear, it is also for a 30mm crank nose.
There is also an aux pulley with a rear flange, but I do not know from which engine it came from.
-Jason Miller
Houston, Texas - USA
philippe74
Post by philippe74 »
hello
I have the same problem on my Fiat 128 engine ...
the belt is moving and I would like to change crankshaft pulley by an other with a flange..
following your remarks, it means a Fiat Uno pulley is OK ? same teeth ?
philippe
Sorry Philippe I gave up on the flanged front pulley idea and used a GC tensioner sleeve on an Integrale type OE tensioner instead.
Sorry for the massive photo.
philippe74
Thanks for your answer
Effectively, it seems to be a good alternative solution ...
May be I will machine my pulley in order to adapt a steel flange ? I don't know
philippe
