Fiat RITMO ABARTH 125TC
AbarthLubos
SPECIFICATION
Fiat Ritmo Abarth 130TC reconstruction to Fiat Ritmo Abarth 125TC ( older model)
ENGINE: 2,0 (1995 ccm)
Engine block was lower – 2mm, because I have pistons from engine 1,6 ( it has bigger crown head).
Serial valves – only turned on a lathe
Serial camshaft from 1.6 TC
Adjustable camshaft drive pulleys
2x Solex 40 ADDHE + pump Facet
GEARBOX : seriál only final drive ratio 3.765
(17/64) from 1,6
CHASSIS: shock absorbers from company HP Sporting CZ
CAR BODY: complete reconstruction, safety frame, and…………..
Horsepower max ONLY 138 !!!???? Serial 130. I do not know why! Serial exhaust pipes 4-2-1 is not adequate and I am making new now.
(17/64) from 1,6
- My old Abarth before reconstruction...
- 1 my car before reconstruction -).JPG (113.52 KiB) Viewed 37383 times
- New front wing after my enlarged
- 2 front wing after my enlarged.jpg (46.46 KiB) Viewed 37383 times
- my home remove of hem - back
- 3 my home remove of hem.jpg (72.67 KiB) Viewed 37381 times
- ..before spraing
- before spaing.jpg (20.05 KiB) Viewed 37375 times
- Pistons from engine 105TC
- 6 pistons from engine Ritmo 105TC.jpg (31.39 KiB) Viewed 37369 times
- reduced piston-road -100grams
- 7 reduced piston -road.jpg (40.5 KiB) Viewed 37367 times
- repaired head with old gasket....
- 8 repaired head with old gasket.jpg (37.51 KiB) Viewed 37370 times
- repaired valve...
- 9 repaired valve.jpg (32.7 KiB) Viewed 37363 times
- I montaged parts of my engine
- montage parts of my engine.jpg (27.23 KiB) Viewed 37360 times
- ..montage of engine to my Abarth..
- montage of engine.jpg (28.96 KiB) Viewed 37355 times
- ..montage of engine...
- montage of engine...jpg (35.33 KiB) Viewed 37351 times
- ...finished montage of engine....
- montage of engine ..jpg (32.23 KiB) Viewed 37351 times
- ...no coment..
- No coment.jpg (28.33 KiB) Viewed 37347 times
- new shock absorber for Group N
- shock absorber.jpg (35.88 KiB) Viewed 37341 times
- after sprayed before montage
- 4 montage of my Abarth.jpg (33.69 KiB) Viewed 37341 times
- ...my home sprayed parts of my Abarth...
- 5 home sprayed parts of my Abarth.jpg (20.31 KiB) Viewed 37340 times
- ..custom-made site with my car..Abarth
- custom-made site with Abarth.jpg (30.07 KiB) Viewed 37341 times
- reservoir from Germany car TRABANT in my Abarth and fuel pump Facet
- reservoir from Trabant and fuel pump Facet.jpg (22.08 KiB) Viewed 37339 times
- view to car
- view to car.jpg (30.36 KiB) Viewed 37343 times
- ..my construction of exhaust..
- my - exhaust.jpg (46.82 KiB) Viewed 37337 times
- absorb exhaust on car
- my exhaust on car.jpg (25.29 KiB) Viewed 37337 times
- me..after two years and 1200 hrs
- me.jpg (27.09 KiB) Viewed 37334 times
- my Abarth
- my Abarth.jpg (27.78 KiB) Viewed 37336 times
- I and my son on first Fiats action..
- I and my son.jpg (25.9 KiB) Viewed 37332 times
- Abarth on brake and big disappointment..only 138 HP
- my Abarth on brake.jpg (28.63 KiB) Viewed 37331 times
- pipes for my new exhaust inside 37 mm, it is +3mm..I need minimally 160 HP :-)
- pipes for my new exhaust inside 37mm.jpg (31.28 KiB) Viewed 37326 times
- Dyno result: to put this kind of power curve in perspective, a 'full race' 1600 8v is NOT going to produce much over 126lbf ft in any spec. Look how driveable it is - see how the torque 'lifts off' from 1500 rpm. Granny could go shopping with this engine.
- 130TC_Lubos annotated.JPG (68.99 KiB) Viewed 37293 times
- new flange for new exhaust - raw parts
- new flange.JPG (72.18 KiB) Viewed 36907 times
Ritmo Abarth125TC
Re: Fiat RITMO ABARTH 125TC
I have very much enjoyed seeing this and it makes a nice change to see the member himself (and son) in the photos, for some reason there appears to be a reluctance to do this among other members; a great pity since it adds an important human dimension. This is supposed to be a forum, after all, not a rather 'dry' on-line manual...
Two points regarding your power. First, the 2 liter 131 engines were equipped with camshafts of nominal lift 9.9 (130TC 10mm), nominal - clearance of 0.4/0.45 in/ex = true lift, whereas the 1600 models had only 9.5mm, so in your case it is likely - measurement will prove this - you are losing 0.5mm of lift which you don't want to do..
Secondly there is much to be had form valve/seat modification on this head, the GC DVD tells you exactly how and what difference it makes. In terms of port size if the head is actual 130TC with the 43.5mm inlets it already has very big ports - 36-35mm approx and unless you are prepping to StIII+ (by my reckoning 175bhp and over) they don't need to be made any bigger, but gains from smoothing the port and esp the SSR (short-side radius where the valve throat runs in to the port floor). If it's a 131/132 head with (nominal) 42mm inlets then the ports need opening up to 36 (at port face) to 34mm at narrowest section. It is worth pointing out that the 130TC head actually had very little by way of SSR, you don't want to chop it off completely, and the reason for that is that it has a much lower port floor than other models. The latter is a perfectly natural consequence of having a bigger port on that type head by the way, the optimum shape is (in my view) round (not D shaped or any other) and if you make the port big, it's going to have a lower floor.
With 130TC cams and head and twin 40s, even with high CR 1.6 liter pistons, the engine is only going to produce about the same as standard, 130bhp or so but with a bit more mid range torque from the higher CR. Fully prepped GC style this is going to go up to about 145bhp, most of that gain coming from the valve/seat and SSR mods. Now add 45 DCOE on 36mm chokes and you're going to be in 155bhp territory - even on the 130TC cams. Those 43.5mm valves are capable of taking the power way higher with a change ot good billet comp cams too. Of course we know it's not just a question of 'power' (ie: bhp) - it's the area under the torque/rpm that really counts. Of course if you lots everywhere, the top end bhp and straight line speed will be high too. But often it's the acceleration from terrific bottom-end and mid range torque that makes the car driveable and exciting. An engine that develops an exciting 190 bhp (which that 130TC head definitely can) at 7500 and soes 140mph (if ever such a thing was safe in a 130TC) but has how can I put this nicely, er, 'modest' torque below 3000 and does 15 miles-to-the-gallon is going to be a bit irksome after a while for road use.
Well done for the way you have executed this project and presented it to us. It is great to see another 130TC being 'saved', and there is plenty of scope for GC style 'supertuning' on this one!
- This head keeps flowing right up to 11.5mm, if you want power, take advantage of that. The inevitable loss with (rough, as-cast) GC offset sidedraft inlet manifold is, in practice, far outweighed by the benefit of having split intake runners ie: one-choke-per-cylinder
- 130TC inlet dev tests from GC DVD.GIF (21.27 KiB) Viewed 37330 times
AbarthLubos
Hi Guy, hi all,
Because mine engine wasn't for me sufficient, I made other from Fiat Coupe 16VT
- old engine before renovation
- 1 12ledna motor před.JPG (101.4 KiB) Viewed 35923 times
- after re-boring and paint
- 2 blok3.JPG (59.6 KiB) Viewed 35922 times
- block
- 4 blokkkkk.JPG (56.62 KiB) Viewed 35921 times
- new parts
- bez šál.JPG (48.91 KiB) Viewed 35920 times
- 16VT head
- palicee.JPG (32.96 KiB) Viewed 35917 times
- comleten engine
- blok z boku.JPG (37.85 KiB) Viewed 35917 times
Ritmo Abarth125TC
Excellent!
Thank goodness there are still a few people out there pursuing a proper hobby!
AbarthLubos
and because with new engine I needen new modification of coachwork, so I am right made drive 4x4 from Fiat Tempra SW :-)
- before
- 1before.JPG (64.17 KiB) Viewed 35901 times
- after
- 2 after.JPG (57.56 KiB) Viewed 35899 times
- before
- tunel před.JPG (61.82 KiB) Viewed 35902 times
- after :-)
- tunelpo.JPG (49.09 KiB) Viewed 35897 times
- before
- zadek před.JPG (63.52 KiB) Viewed 35899 times
- after
- zadek po.JPG (64.78 KiB) Viewed 35898 times
- I and mine son 29.3.2009
- spolu.jpg (62.55 KiB) Viewed 35897 times
Ritmo Abarth125TC
AbarthLubos
after montage 29.3.2009
- rear
- zadní náprava.jpg (52.34 KiB) Viewed 35896 times
- front
- předek.jpg (73.36 KiB) Viewed 35891 times
- kardan.jpg (66.39 KiB) Viewed 35890 times
Ritmo Abarth125TC
You need to go round that carefully prepared car and make sure that ALL paint is removed where there is a threaded joint eg: nut & bolt.
Paint is soft and allows the preload to come off and the joint can work loose. If you want paint - paint after bolting-up.
Just a quick tech note,
AbarthLubos
Small progress..
- engine in body and without front girder
- aa.jpg (75.97 KiB) Viewed 35301 times
- new one
- DSCF8460.jpg (99.43 KiB) Viewed 35298 times
- lamella
- lamela.jpg (63.73 KiB) Viewed 35297 times
- lamella
- lamelaa.jpg (78.42 KiB) Viewed 35298 times
- adjustment
- DSCF8063.jpg (74.84 KiB) Viewed 35298 times
- engine in body
- engine in body.JPG (65.08 KiB) Viewed 35298 times
- back
- Snímek 127.jpg (77.61 KiB) Viewed 35297 times
- front
- výfuk.jpg (76.93 KiB) Viewed 35296 times
Ritmo Abarth125TC
A nice project & thread with some really good photos!
Well done!
Well done!
AbarthLubos
AbarthLubos
Hi all, small advancement from last time :-)
- new exhaust by my 61 mm inside for test.JPG (97.73 KiB) Viewed 34770 times
Ritmo Abarth125TC
AbarthLubos
AbarthLubos wrote:Hi all, small advancement from last time :-)
- b.JPG (110.84 KiB) Viewed 34770 times
Ritmo Abarth125TC
AbarthLubos
AbarthLubos wrote:AbarthLubos wrote:Hi all, small advancement from last time :-)
- c.JPG (89.88 KiB) Viewed 34770 times
Ritmo Abarth125TC
AbarthLubos
AbarthLubos wrote:AbarthLubos wrote:AbarthLubos wrote:Hi all, small advancement from last time :-)
- a jurney todown.JPG (87.43 KiB) Viewed 34770 times
Ritmo Abarth125TC
AbarthLubos
news
- e.JPG (73.25 KiB) Viewed 34770 times
- new pipe from Kappa.JPG (77.26 KiB) Viewed 34770 times
Ritmo Abarth125TC
