What gearbox do I have on my Fiat Twin-Cam?
Posted: June 2nd, 2007, 10:20 pm
Firstly, I would like to say hello.
I am running a Fiat Twin Cam Abarth engine in my Westfield. What a cracking little motor. Mine's running on rally cams, vernier pulley, twin 45's etc...
I have a Fiat manual box attached to it. I can not find a number on it so I do not know what the part numbers are for any spares?
I'll explain what the gearbox unit looks like and maybe someone can tell me the type of gearbox it is? And relating partnumbers so I can get gaskets for it......
Bottom of the gearbox has a removable sump plate approximately 25cm-15cm, held by +-12 bolts and an oil draining bolt just off the centre?
Oil filler plug is on the driver's side (RHD - UK). Its a very large female bolt 29mm in diameter.
I think thats all I can tell you? Thanks in advance for any replies.
Menno
Menno
