For my conversion project i have an aluminium BMW 16v head. it is in good condition and as spares are rather expensive i would be tempted to leave well enough alone.
As several oil drainback channels do not match the block I am mating it to, the common method is to TIG weld aluminium plugs into the head to block the passages.
I am very wary of this.
As far as i know you cannot properly weld a aluminium head without pulling seats, guides and putting it through heat treating and fully remachining it.
As you have extensive experiences with the ressurection of fallen aluminium race heads...
Am i being too cautious?
To circumvent the problem I'd much rather glue/epoxy the plugs into the head. If you can glue an airbus A380 together a simple plug should not be impossible i should think.
do you think this is a better practice as this is purely a port for oil drainback and does not need to withstand much?
thank you
Joost
welding an aluminium head (not for repair or port work)
SirYun
Joost M. Riphagen
SirYun
