Hi everybody... I'm just wondering after how many miles should you compression check a freshly built engine?
Thanks in advance for any advice
Ant
when to compression test a newly built engine??
You'll see about the highest it's going to achieve on a compression test within a very short time, 20 miles is the lowest I've done that, though that's not to say at all that the rings will have bedded in fully by then (and oil consumption stabilised). That takes way longer. The valves and seats bed in seconds.
For info: Hot engine, all plugs out, wide open throttle, isolate injection/ignition otherwise you might pump gasoline straight into the catalytic converter and light it up when you restart.
It should take no more than 2 or three strokes to achieve peak pressure, don't stop cranking until the gauge stops climbing. There are reasons for slow rate of climb if that is what you find.
I've just read this thread and was wondering what sort of pressure you would be looking at for a relitavley standard 2ltr Fiat TC? with 9:1 CR and the GC recomended valve/seat work.
Would a highly tuned motor have any more compression at cranking speed or does most of the modfications come into place once the engine is actally running?
I have ghad a quick test of my compression. It seemed a bit low but the engine is still very fresh. The pressures were all very even though.
Gill
Gill
Hello:
In my new rebuilt 1919 ccm Beta motor with 50 ccm combustion chamber, after 400 km road test , I found the following compresion numbers. I don‚´t know if they are very good or not, but are very similar.
Cylinder 1 2 3 4
Static 195 192 192 185
Idle 50 70 50 55
All are psi.
Best regards,
Siro,
Cylinder 1 2 3 4
Idle 50 70 50 55
All are psi.
Best regards,
Siro,
- Imagen013.jpg (39.24 KiB) Viewed 4432 times
