Ford CVH stainless valves - guide material
leeuk
Post by leeuk »
Hi Guy
I'm running a cvh rs turbo with big valves the stainless 214n type
i read on your site that you need to use bronze guides with stainless valves
but i am using the standard guides and i am now worried that my engine is going to fail
can you confirm that i need to use bronze guides with these valves ?
Stainless 43mm 214n CVH inlet valve
CV370 Valve.jpg (6.12 KiB) Viewed 6905 times
Lee, hi
well, you should not run plain stainless (eg 21-4n) against cast iron guides, it tends to gall.
Check to see if your valves have also got chromed stems or have been plasma nitrided, because they are both OK with cast iron guides.
Mats
Post by Mats »
How would one check that?
/Mats Strandberg
I could see that question coming!
First thing is to ask the supplier. Second - you can spot the chrome plating because it's only on the stem and a different color from the stainless, plus it's way harder.
The plasma nitriding gives the valves a smokey-black sheen. If the valves are from G&S in UK they may well be of the latter type.
