Integrale 8V - Valves, Valve Seats, Comb.chambers and more
Posted: January 21st, 2007, 3:33 am
Mr. Guy Croft!
I am currently rebuilding a Integrale 8V head after a chipped exhaust valve. In this process quite a few questions and discussions have come to the surface:
1)
Are the exhaustvalves of the Integrale 8V sodiumfilled?
If so are there ways to easily distinguish them from the NA valves?
Please help out here - the discussions have been quite heated....
Even the people that are supposed to know - Like Fiat/Lancia and different engine parts suppliers - wildly disagrees regarding these questions!!
(Btw I ordered some sodium cooled...)
2)
What valve seat contact face width do you recommend for this engine(fast road) running standard boost (1bar) ?
3)
Why has the Integrale 8V head sooo bad finish?
After all its newer and has been redesigned compared to the 130TC`s I usually look at...
Here are some pics
- Huge edges between seat and valve throat....
- Large flakes of aluminium that rises up in the area of the valve guide... in two ports
- Edge between the cast areas and the machined area of the valve"bowl" are so sharp that they make a real bumps!
- Casting flashes - lots
- A 90` edge rising some places to more than 2 mm over the valve seat.
- General rough finish
- Walls of combustion chamber very close to intakevalves
I`m a bit shocked.......
4)
The Integrale has in its original form an inlet cam with longer duration and higher lift than the exhaust cam. The NA engines all have similar intake/exhaust cams.
What is the real reasoning behind this?
I just cannot understand the argument that this prevents of the high inlet charge from escaping out the exhaust. The high inlet charge comes from the exhaust pressure/energy, and the exhaust ports must therefor be equally or higher pressurised than the inlet side? (at least most of the time...)
In my head the turbo engine is a kind of closed system operating at higher pressure than a normally aspirated one... but in principle operating the same way.
Please explain - I really need to know - I don`t know too much about turbo engines.
5)
A question regarding Oil Consumtion.
By keyholing/modifying the crankshaft as in Your book - will oil consumtion tend to rise as a result of more oil being sprayed up under the pistons?
Thank You very much for Your answers - lovely site!!!
BTW: The head in the pictures is now finished and will recieve a set of GC race guides this week :!:
Last a bragging picture of an intake port before and after:
Best regards
Remi Lovhoiden
1)
2)
3)
Here are some pics
4)
5)
Best regards
Remi Lovhoiden
