Valves hitting each other or piston, limits?
Posted: January 11th, 2007, 3:22 pm
Is it possible to give any rule of thumb (is that correct way to say) for how much lift and degrees an engine can take without modifications to pistons?
Engine would be 130TC based with Regata 100 pistons, 130TC head gasket and standard valves.
I am upgrading camshafts, but I want to do it without lifting the head off the block.
Could it accept 11,1mm of lift?
I have heard that TC suffers more often from valve to valve contact, but is that because of incorrect timing or what?
How can I check that there is enough clearance that valve to valve contact doesn't happen?
