Specs of Peugeot 106 1.3 and 1.6 Rallye cams
romilos
Post by romilos »
Does anyone know the specs of Peugeot 106 1.3 and 1.6 (8V) Rallye cams?
I wanted to know...
1)duration (inlet and outlet) @0.05"
2)Lobe center angle
3)Degreed center line
4)Valve lift (intake-exhaust)
More critical for me are 2 and 3.
The only way you are going to get that info is to send examples of the actual cams to a cam manufacturer like Kent or Piper or to someone with a 'Cam Doctor' digital system and ask them to 'map' them.
rossd
Post by rossd »
To drag this topic up from the bowels of the forum....
I have got some basic specs on these cams on my website, the only problem is they are manufacturer figures and they have been measured at 0.7mm and not 0.05". I haven't got your points 2) and 3) though I'm afraid.
As you probably know, the 1.6 and 1.3 engines in the 106 Rallye share the same cam.
craigb
Cam Spec
Post by craigb »
The GP A cam that was supplied to me from PTS some time ago was a Piper profile. I will have a look to see if i can dig out the Cam Number
