Fiat 8v OE cams potential - 1.6 liter vs 2 liter
mike_torello
Post by mike_torello »
1600 8v i.e. Lancia cam
vs.
2 liter 8v carb. Fiat cam
Which one's are better? I mean, will power increase if I put these from 2.0 to 1.6?
BTW. are the heads the same on these two engines? Valves?
Thank you
Mike, hi
if you are talking about early (non reversed port) engines then the 1600 cams will be lower lift than the 2 liter, ie: 9.5mm nominal lift compared with 9.9mm. So use the 2 liter cams, OK?
As far as heads with bigger inlet valves (43.5mm compared with earlier 42mm) are concerned see:
http://guy-croft.com/viewtopic.php?p=1094#1094
Let me know if you need more advice but please make sure you quote full engine details (outline spec) or else I'll find myself having to describe two engines-for-the-price-of-one...!
