The Lancia Delta, 8 valve engine uses what appears to be a high temperature plastic intake manifold gasket / spacer. At first I assumed it was phenolic, but after using a belt sander on it, it did not emit the characteristic phenolic smell, thus I think its a high temperature plastic. Its 0.200 inches or 5.1mm thick. It also has thin paper gasket material bonded to both sides. I don't have a Delta shop manual so I don't know if this gasket/spacer needs seperate gaskets installed on both sides or the thin paper gaskets bonded to the plastic spacer is sufficient. The paper gaskets seem pretty thin to be able to accommodate imperfections on the mating faces of the manifold and head. What does the Delta shop manual manual indicate?
Tom McG
Lancia Delta 8V intake manifold gasket/spacer
tmvolumex
tmvolumex
Re: Lancia Delta 8V intake manifold gasket/spacer
I forgot to add: I actually think this gasket/spacer is a thermal insulator to prevent excess heating of the intake charge due to heating of the intake manifold bolted to the engine cylinder head.
GC_31
No extra gaskets Tom but silicone sealant recommended around the water outlets on the head..
tmvolumex
