Volumex supercharger overhaul - rebuild
Supercharging, turbocharging, charge cooling
Locked
Showing steps in the rebuild of the low pressure supercharger used on the Lancia Volumex (Vx) unit. (The 'MM' prefix with the photos is the client's initials)
Rotors, main casing and front, rear housings after decarbonising, dressing and beadblasting, ready for Xylan coating.
MM Vx parts cleaned.jpg (108.13 KiB) Viewed 447114 times
Internal parts pre-cleaned, gears, thrust washers, nuts etc
a 058.jpg (115.66 KiB) Viewed 447097 times
End covers and rotors coated with Xylan 1010 conductive polymer, this gives lower friction, quieter running and reduced clearances/better performance and less power loss.
a 062.jpg (111.85 KiB) Viewed 447074 times
New rear seals oiled lightly on outer diameter and ...
a 064.jpg (118.08 KiB) Viewed 447069 times
...gently pushed into place by hand using a special drift, they must sit square and sit right in their machined recess.
a 065.jpg (117.66 KiB) Viewed 447045 times
..whereas the front seals need a bit of help from the press after initial location by hand, again oiled on OD or they will never go in properly and likely end up torn (and leaky)
a 066.jpg (114.4 KiB) Viewed 447032 times
A press, and modest pressure with a decent mandrel needed to seat the front seals.
a 067.jpg (115.97 KiB) Viewed 447011 times
Remove the inner sleeve and oil the OD of the rear bearings and press in gently down to their seat, nice and square.
a 068.jpg (107.88 KiB) Viewed 447003 times
Rear bearings fitted, sleeves refitted, they should turn freely if the brgs are fitted properly. I like to have the number code facing out so you can see what's in there..
a 069.jpg (119.63 KiB) Viewed 446990 times
Here is the front bearing, an SKF four-point contact type that I have had precision-reworked to 'C2' close axial tolerance. Position one inner sleeve in the front casing and ...
MM_01 Vx rebuild 001.jpg (117.74 KiB) Viewed 446970 times
One front bearing pressed into place
MM_01 Vx rebuild 003.jpg (115.58 KiB) Viewed 446958 times
With both bearings fitted and their outer sleeves installed the bearing retaining plate can be fitted, fit new spring washers and tighten the M6 nuts to 8lbf ft.
MM_01 Vx rebuild 007.jpg (116.82 KiB) Viewed 446952 times
Locked
