Hello guys;
My Delta HF HPE 2.0 16v turbo is spitting oil out of the cylinder head cover breather, the place where you have a pipe that goes into the oil canister and to the air filter pipe, I realised that my car is smoking white smoke big time, so after checking I found that the source is the head cover, so I disconnected the pipe that goes from the canister to the air filter line and the smoke stopped, but the oil was all over the air filter box now.
Why would an engine spit oil from the breather, engine is newly built and everything was changed in the block, pistons, rings, journals etc....
is it possible that something is making pressure accumulate inside the head? or there is something wrong with the head cover?
Kind regards
Nabil
Lancia Delta HPE 16v Turbo oil loss through breather
nabilhpe
Nabil,
That is probably blow-gas by from the piston rings not bedding - causing pressure in the crankcase - unless you did not connect the breather pipe with its rubber seal correctly in the block.
Last edited by Guy Croft on September 2nd, 2006, 12:31 pm, edited 1 time in total.
nabilhpe
nabilhpe
