Some GC heads prepped this year
porting, development, valve and seat work, combustion chambers, cams, head construction, etc
Locked
See pics attached..
HS 2.3 big valve conversion
BW_final ops post port correction (5).JPG (123.37 KiB) Viewed 103464 times
16v Tipo
16v Tipo
OD 16v 21 Mar 14 (6).JPG (124.14 KiB) Viewed 103464 times
OD 16v 21 Mar 14 (18).JPG (121.26 KiB) Viewed 103464 times
Duratec 16v ST 170
Duratec 16v ST 170
TN Duratec_valve tip corr (6).JPG (679.37 KiB) Viewed 103464 times
TN Duratec_full head build & checks (9).JPG (125.06 KiB) Viewed 103464 times
Lancia Volumex - was..
Lancia Volumex - is ...
MT VX assembly of head with valves.JPG (119.95 KiB) Viewed 103464 times
MT VX assembly of head with valves (6).JPG (144.93 KiB) Viewed 103464 times
Fiat 125 1608 - was ...
FP 125 valve seat lapping (1).JPG (126.5 KiB) Viewed 103464 times
Fiat 125 1608 - is ...
FP 125 valve leak testing prior to build (1).JPG (130.44 KiB) Viewed 103464 times
VW Golf GTi - was ....
VW Golf GTi - is ...
LVW_4 final head ops (6).JPG (116.58 KiB) Viewed 103464 times
BMW M Div S14
BMW M Div S14
NB BMW_ (21).JPG (109.43 KiB) Viewed 103464 times
'Works Replica' Fiat-Abarth 124 CSA 2 liter big valve conversion
1 (95).JPG (144.02 KiB) Viewed 103464 times
Alfa Spider TC 1600..
JW Alfa 02.JPG (141.58 KiB) Viewed 103464 times
JW Alfa 02 (5).JPG (120.3 KiB) Viewed 103464 times
JW Alfa 02 (10).JPG (128.14 KiB) Viewed 103464 times
JW Alfa 02 (13).JPG (131.59 KiB) Viewed 103464 times
JW Alfa 02 (16).JPG (125.34 KiB) Viewed 103464 times
JW Alfa 02 (14).JPG (121.24 KiB) Viewed 103464 times
2 liter Beta for Stratos replica
PE Beta_ (8).JPG (114.33 KiB) Viewed 103464 times
selective honing for overhauled valves on GC guides
PE_Beta selective honing at 180 and then 240 grade (1).JPG (604.1 KiB) Viewed 103464 times
dressing the carbs on the GC offset Beta manifold
PE_carb fitting (1).JPG (517.39 KiB) Viewed 103464 times
another monster valve XK 120 Jag head for CKL Developments
CKL_02- (6).JPG (106.13 KiB) Viewed 103464 times
NHRA spec full-race 2liter Fiat TC head
SH 124 head build (2).JPG (126.6 KiB) Viewed 103464 times
SH 124 head build (10).JPG (101.84 KiB) Viewed 103464 times
Re: Some GC heads prepped this year
Post by Piotrek125p »
Is there a chance for 2015/2016 update ? ;-)
Locked
