Is my Block now scrap ?
Posted: January 5th, 2013, 11:21 pm
by Farmer
You may remember I'm in the process of rebuilding my 131 Super Mirafiori engine (1.6) Due to poor running and oil pressure failing . I finally got around to prizing the engine out of my Formula 27 sports car, took the head off first today and have noticed what looks like a crack running round the bore of no.3 cylinder. I've not noticed any compression in the water but I'm guessing it's just a matter of time before the crack gets worse and I end up with no 3 piston escaping through the side . Any comments greatly appreciated .
Re: Is my Block now scrap ?
Posted: January 6th, 2013, 12:58 pm
I see some undercutting thru coolant corrosion due to a head gasket failure or leakage some time ago but I don't see a crack, I've never had a TC bore crack but I've seen others and it is always a vertical crack. Don't see one here..
Posted: January 11th, 2013, 1:54 am
by Farmer
Thanks for the reply Guy
Ironically I was in our capital city this afternoon for a meeting (plus a rather frustrating, hour long, diversion due to an accident on the main road up through the city centre) My time would have been better served bringing it up for your closer inspection . However if you have never seen a cracked bore like this I have to trust your experience as this is the only TC I've looked at. So what am I looking at here?
I'll show another view here
Posted: January 11th, 2013, 10:52 am
A rebore would prove this out, I have seen the like before (often) - I think it is more likely to be corrosion staining since it is of the shape you would get if water was sitting on top of the piston.
If you rebore you'd best talk to me, OE pistons are not aval anymore - which is one reason all GC units are on forged.
Posted: January 11th, 2013, 3:41 pm
by Farmer
Thanks Guy
I outlined the erratic diagonal "crack -like " line . Just to be sure, I am not referring to the rusty line at the top , that is most likely caused by the engine standing idle in an un-heated shed for about 12 years between rebuilding it and starting it . condensation I would think. I'll have to take it to my local engine re-bore emporium to see what they say .
Kind regards
Ian
Posted: January 11th, 2013, 4:38 pm
I say again:
"If you rebore you'd best talk to me, OE pistons are not aval anymore - which is one reason all GC units are on forged..."
If you let anyone loose on it without talking to me first (which is why I run this forum) you will render it scrap.
Posted: January 11th, 2013, 5:10 pm
by Farmer
Thanks Guy
Duly noted , I'll look at my options and probably try to fit in another trip to the capital , I certainly wasn't suggesting I'd do anything without extreme caution as the engine is now well over 30 and replacing anything is not necessarily straightforward
Ian
Posted: January 17th, 2013, 1:29 am
by Farmer
I paid a visit to Twin Cam central yesterday and had a very agreeable chat with Guy , he explained the damage I was concerned about and laid out the options he could offer . Most of these options are sadly beyond my budget, as the indisputably correct, un-compromised, Guy Croft route would easily double my previous investment in my precious car. My investment in the car is Heart and Soul over money , and ingenuity over ultimate ability. I will find a route that suits my compromised budget , whilst also acknowledging the lessons freely and warmly given by Guy.
Thanks for your valuable time and experience .
Ian
