Valve to valve clearance during overlap
Posted: December 9th, 2012, 1:19 pm
I read the 1rst book and found your recommendation for valve to piston clearance during overlap.
But what are the figures for the valve to valve clearance? I mean if you increase the intake valve size diameter you have this dimension decreasing so what is the limit to respect?
It is for the R5 Alpine engine built by a friend (the intake valve going from 38.5 to 41.5 mm) as we discussed previously concerning the head prep.
Thank you,
Robert
Thank you,
Robert
