Flywheel bushes - sizes.
Posted: April 11th, 2012, 7:16 pm
by Abarthnorway - Remi L
Hi Guy!
During my current engine build I discovered some differences between flywheels from the 131 and 130TC Abarth:
130TC web.jpg (100.3 KiB) Viewed 16676 times
Here is a std 130 TC flywheel with a bush in the centre.
131 non fit web.jpg (86.71 KiB) Viewed 16676 times
Here is the 131 flywheel I am planning to use - the bush is too small to fit into the central hole...
I never thought of measuring this as I thought it would be "plug and play" - not so.
Is there any "system to it" - regarding differences between the flywheels in the Fiat Lancia family?
Best regards
Remi Lovhoiden
Re: Flywheel bushes - sizes.
Posted: April 12th, 2012, 9:09 am
we have a sleeve for that Remi
Posted: April 13th, 2012, 2:01 pm
Thank You!
Remi
Re: Flywheel bushes RWD vs FWD applications
Posted: April 18th, 2012, 3:06 pm
by tmvolumex
Maybe I am mistaken, but I remember something about the transverse (Beta FWD and Montecarlo / Scorpion) twin cam installations using a solid metal bushing while the RWD installations require a ball bearing. A ball bearing would work in the transverse applications but is not a requirement? It never really made sense to me, maybe Guy could clear this up.
Re: Flywheel bushes FWD vs RWD
Posted: April 18th, 2012, 3:10 pm
by tmvolumex
It may be that the input shaft on the FWD transaxle applications does not actually go into the bushing / bearing as it is short. The bushing is only used to center the flywheel?
Posted: April 18th, 2012, 3:19 pm
that is correct Tom
