Hi all,
Having fitted an N/A inlet cam from a delta gt i.e. to my hf turbo i.e. and felt the benefits, I would like to do the same to my 16v engine before i put it into my Delta Evo. The typical choice was a 16v Tipo Sedici inlet cam but they're getting somewhat rare these days. Does anyone know if the inlet cam from an N/A 16v Fiat Coupe would have a similar effect?
Thanks for any ideas,
Guy
Integrale 16v N/A inlet cam upgrade - would Fiat coupe work?
Infectus-Guy
Re: Integrale 16v N/A inlet cam upgrade - would Fiat coupe w
You could use any n/a 16v inlet cam, yes.
Fingers
I'm interested to hear your impressions on the cam upgrade in your HF. Did you do any other mods?
Book # 34
Infectus-Guy
Have been given a tip-off! Nik pointed me towards this info-
16v Turbo
Inlet lift- 8.6mm
Exhaust lift- 7.5mm
16v N/A
Inlet lift- 9.57mm
Exhaust lift- 9.57mm
Not sure how it compares to the tipo cams, but the N/A certainly has more lift.
Guy
16v Turbo
Inlet lift- 8.6mm
Exhaust lift- 7.5mm
16v N/A
Inlet lift- 9.57mm
Guy
GC book #182
