Scored main bearings
Posted: June 28th, 2010, 5:56 am
Engine is a Fiat 2000cc Twincam, high performance street engine, naturally aspirated.
I am baffled by scored main bearings after less then 800 miles. Previously we had an oil leak on the
dyno at the oil filter block, which cause less than ideal pressure. At that time the rod bearings
were scored, so we replaced them along with the mains. We also changed to forged pistons since
the engine was apart.
Oil pressure is good, oil pump is an original Fiat one installed new when the engine was first built
last summer, and we use Valvoline VR1 20w50 racing oil. Crankshaft was not turned, bearings are
standard. Clearances checked out when the engine was built.
There was very light (one line) scoring on the upper rod bearings. I attached a pic, but I am not
sure if it will show up. Also attached a pic of the main bearings.
Any ideas would be appreciated.
Csaba
Csaba
