Removing Core/Freeze Plugs out of the block
Dunc
Post by Dunc »
Hi all,
I'm currently having much difficulty in removing the old core plugs from my 2.0 TC engine.
Does anyone have a method, or general help and advice they could give me? As these seem to be stuck fast!
I've tried to peirce a hole in the middle of one to get a screwdriver in to try prising it out but this isnt shifting it?
Also, where can i buy new core plugs from? I'm hoping GC can help me here!
Thanks in advance
Dunc
4v6
Re: Removing Core/Freeze Plugs out of the block
Post by 4v6 »
Its usual to use a punch to carefully cock the plugs over so they release their grip and they can then be removed with pliers or long mole grips.
Dosnt always work mind you as some engines tend to have a cast in "seat" behind which interferes with the operation.
With really stubborn ones, i usually drill a series of connecting holes across the middle and this helps to relieve some of the pressure on the periphery so they can be carefully pryed out.
Tony Warren. GC #96.
Dunc
Post by Dunc »
Thanks for your fast response!
The drill idea was next on my 'to do' list! Thanks again,
Will be in the garage tonight giving it a go!
Dunc
straight out of my new book which goes to print very shortly,
3.12_core plugs removal_tap.jpg (109.3 KiB) Viewed 12007 times
3.13_core plugs removal_tilt.jpg (119.21 KiB) Viewed 12007 times
3.14_core plugs removal_lever.jpg (118.46 KiB) Viewed 12007 times
Dunc
Post by Dunc »
Thanks Guy!
I shall attempt this tonight!
thank you again for the pics.
Dunc
Alejoint
Post by Alejoint »
It's not a bad idea to leave a screw in the holes you have previously drilled on the plugs. Sometimes the plugs will like to go straight into the water jacket instead of being shifted sideways (I know it because I've been there myself), if you tie a piece of string to those screws you can easily "fish" them out if they happen to fall inside the block.
Users browsing this forum: No registered users and 45 guests
