Valve clearance, steel valves vs. stainless valves.
Posted: May 29th, 2010, 1:13 pm
Hi
I'm currently building an Alfa Romeo Nord turbo engine. The base is a 2 liter engine and basically everything except crank is replaced. The block is done and I'm now mounting the valves in the head. When I measured the clearance with the old shims during a mock-up the other day I realized I had no idea what clearances to run.
The setup: Stainless valves (stock sizes 44/40), head is unmodified in respect of the valvtrain measurments, catcams steel camshafts designed for Naturally Aspirated (N/A) engines. Clearances spec. as per camshaft maker is 0.2mm intake/exhaust.
Now, as I sat there my mind started to think about thermal expansion and the tight (compared to stock Alfa) clearances in the camshaft spec sheet. Stainelss expands a lot more then regular steel but then again the conductivity is lower, so what will hapen when I start racing with this engine, will the clearance be too tight on the exhaust side since the exhausts will probably be hotter then a N/A engine?
Is this just a problem in theory? Will everything just work in practice and all different properties even eachother out?
