Anti torque stay for Montecarlo engine
Robert
Post by Robert »
On the Montecarlo the engine is supported by 3 rubber bush/mounts and I think the engine moves a lot and the exhaust suffers of that in "fast road/track day" conditions (I've re-welded 3 times it). I know that on Lancia Beta there is a stay from the head to the body in order to have limited movement of the engine. But I don't know how it is fitted on the head.
My engine being a 130TC (from Strada) I plan to mount a stay from the rear body part of the Montecarlo (welding a bracket) to the head. Each side of the stay has a silentbloc (Paulstra bush) in elastomer. I plan to use the threaded hole on the intake side near cylinder n°4 (flywheel side) as fixation point. This allows to use a 12mm dia screw.
Do you think the head is enough solid at this level to accept this constraint ? Hoping I'm clear enough.
Thank you
Robert
PS I let you correct the title if not correct
GC_131
Re: Anti torque stay for Montecarlo engine
Brace off the crankcase - at the gearbox end - would be my strong advice. Bracing off the head puts an undesirable load on the head-block-gasket joint. Norman Singleton In Australia figured this out and kindly brought it to my attention when he kept blowing gaskets on his X19 16v racecar (another transverse unit)
ASF72
Post by ASF72 »
I don't know if this will help here but I kind have had the same problem with my Lancia Delta Integrale. With movement of the engine under hard use the top engine mount stabiliser bracket had snapped off, I have had it re welded on several times only for it to crack and break after the new weld again so i thought i would create something new.
I have read about engine dampers and it seems that all the Honda boys use these to stop wheel hop and engine movement so I got my friend to weld a bracket on which i made and the rest was easy, hardly no engine movement but dampened.
Nino
Users browsing this forum: No registered users and 53 guests
