Page 5 of 11
Posted: April 15th, 2013, 11:17 pm
by Simon
Time for an update:
Having got the current 2l lump running and finding the head gasket problem, I need to decide what to do engine wise in order to have something useable and bedded in for a club event in October. I have got the money at the moment do my intended GC spec rebuild on the 2.0, and don't want to spend time just fixing the head gasket on what is a pretty clapped out unit anyway. Its also a low compression US spec. So as a 'stop gap' I have decided to do a basic rebuild on an 1800 lump I have had in storage for a while, as it looks to have had a rebore and new pistons, before the owner started an X19 conversion. In theory it could be made into something useable after a strip, clean and rebuild with new rings and bearings, and fitted with a head I have half prepped for the 2l.
So last Sunday I dragged it out of storage and got it mounted on the stand ready to strip down and decide if it was the right way to go. This evening I started the strip down:
- 1800 block
- _IGP0026.jpg (587.31 KiB) Viewed 25610 times
- Fabricated sump for an X19 conversion - builder must have worked in the ship yards!
- _IGP0031.jpg (433.15 KiB) Viewed 25610 times
- Sump removed. The oil pickup will need swapping to RWD sump configuration
- _IGP0040.jpg (491.56 KiB) Viewed 25610 times
- Crank removed
- _IGP0078.jpg (518.15 KiB) Viewed 25610 times
All was looking good until I released No. 2 big end and found this mess...
- No.2 big end shells - ouch!
- _IGP0058.jpg (365.57 KiB) Viewed 25610 times
- OEM size
- _IGP0064.jpg (299.52 KiB) Viewed 25610 times
Judging by the flattened 'ear', it looks like one of the shells was put in the wrong way round. Unfortunately, the shells dropped into the block when I released the cap so cannot be sure. Anyway, the crank journals all looks good and the rest of the shells look reasonable and are OEM sizes. I need to do some proper measuring though. I see if I can find time to continue tomorrow evening.
Posted: April 16th, 2013, 11:54 pm
by Simon
Posted: April 17th, 2013, 10:53 pm
by Simon
Spent an hour this evening unplugging the crank...
- Better out than in!
- _IGP0115.jpg (361.8 KiB) Viewed 25571 times
- Plugs removed ready for cleaning
- _IGP0118.jpg (401.66 KiB) Viewed 25571 times
Posted: April 20th, 2013, 10:49 pm
by Simon
Posted: April 28th, 2013, 8:57 pm
by Simon
Posted: May 6th, 2013, 10:31 pm
by Simon
The long weekend gave me chance to make a decent amount of progress. I actually found a top end gasket set in amongst my 'stock' so decided to spend Saturday fixing the leaking head gasket on the existing engine and attempt to get the car mobile under its own steam. That all went surprisingly well and after buying a battery and some antifreeze on Sunday morning I had the thing running again, albeit with a temporary coolant hose and ignition wiring arrangement, I managed to drive it out into the sunshine!
- Engine running sweetly and leak free again with temporary hosing and HT wiring.
- _IGP0304.jpg (523.12 KiB) Viewed 25395 times
Then today in yet more wonderful sunshine I prepped the roof moulding and applied a couple of layers of polyester, ready for priming.
- Roof almost ready for priming.
- _IGP0303.jpg (366.46 KiB) Viewed 25395 times
I am now in a bit of a quandary over my intended Olio Fiat inspired colour scheme, which I thought would be great for a track car, but I've realised it is not really acceptable for most road rally events, so I might have to have a rethink.
Posted: May 7th, 2013, 1:20 am
by miro-1980
Simon,
Watching your progress with grate interest. please keep it coming !
What seats are you planning to use ?
When you work on their installation I would appreciate some pictures.
I was dry fitting replica 131 abarth seats ( which I have also seen in 124 abarths. They fitted Ok, but I ma still thinking of hot to bolt them to the chassis.
Would like to see how you solve this problem.
Posted: May 7th, 2013, 8:44 am
very nice to see my methods being used on the crank, well done!!
Superbly illustrated thread with great wording too.
Posted: May 7th, 2013, 1:03 pm
by Simon
Thanks Guy, I quite enjoyed getting to work on an engine again and finally having a go at some of the processes I have been looking at with great interest on here for so long. At least now that I have the original engine running again it takes the pressure of the 1800 build, which can now be done with a bit more thought and time. I will soon be ready to send you the head to get the GC guides pressed in.
This project seemed to turn a bit of a corner at the weekend and now feels more like just repairing a car than building one!
Regarding the seats Miro, I am initially using some old Magnum (they went out of business several years ago) lightweight fibreglass buckets salvaged from my Lada Niva. I was amazed to find that the runners off the factory seats lined up with the mounting rails on the Magnums and only required a new hole to be drilled to line up the mounting holes. So there wasn't really much problem solving to do. The conventional competition car method it to use two parallel tubes (25 dia?) that mount between the tunnel and sill with (front and rear of the seat). The tubes mount through drilled holes with reinforcement plates, which are all then welded up - you can buy a kit (the two tubes + 4 reinforcing plates) from most rally prep suppliers. I may go down this route eventually, but happy to use the factory mounts for the time being.
Here's a pic of the Magnum seat, I'll load up something more illustrative when I fit them in for the last time (they're constantly in and out at the moment whilst I am doing other jobs.)
- Magnum bucket seat
- _IGP4801.jpg (36.82 KiB) Viewed 25368 times
Posted: May 12th, 2013, 8:48 pm
by Simon
Posted: May 25th, 2013, 7:59 pm
by GaryR
Hello Simon! We met this morning (your postie). The Spider looks fantastic! I've really enjoyed reading this thread and looking forward to seeing the finished article.
Kind regards.
Gary.
Posted: May 27th, 2013, 11:27 pm
by Simon
Hi Gary, it was great to have a natter; its not everyday the postman hands you a letter then asks, 'Has it got a full Gut Croft under the bonnet?' :-) You need to post up some pictures of your 124 Coupe, it sounds like its a real stunner!
Well, I now have a new deadline of July 7th for our clubs stand at Go Motorsport Live at Silverstone, so fortunately I made quite a bit of progress over the long weekend, making use of the nice sunny weather to get on with some painting. Since doing the satin black paint job I realised it was not the most practical of finishes, and since I still needed to apply my chosen colour scheme to the arches and lower panels I decided to go for a gloss clearcoat over the hole lot. Unfortunately there is one hour time window for apply it, so it meant I have to reapply the black basecoat, then the colour scheme, the the clearcoat on top of that within the timeframe.
Before starting on the paint I still needed to make the holes for the front side repeaters....
- Position marked
- _IGP0352.jpg (268.45 KiB) Viewed 26339 times
- A bit brutal but an 18 mm hole was required.
- _IGP0347.jpg (276.17 KiB) Viewed 26339 times
- Fiat 500 side repeater trial fit
- _IGP0351.jpg (321.89 KiB) Viewed 26339 times
- Flatted down with 1200 grade and masked up for fresh black basecoat, the 1 hour window starts now!
- _IGP0684.jpg (303.84 KiB) Viewed 26339 times
- Whilst I had the black basecoat in the gun I gave the primered bonnet an bootlid a coat.
- _IGP0689.jpg (275.33 KiB) Viewed 26339 times
- A touch of colour!
- _IGP0688.jpg (328.69 KiB) Viewed 26339 times
- More masking then on with the colour.
- _IGP0691.jpg (363.39 KiB) Viewed 26339 times
- Masking removed and first coat of clear
- _IGP0693.jpg (349.05 KiB) Viewed 26339 times
- Waiting for clearcoat to harden.
- _IGP0696.jpg (396.99 KiB) Viewed 26339 times
- Two more coats of clear, with flatted between coats, then off with the masking for the last time!
- _IGP0699.jpg (394.66 KiB) Viewed 26339 times
- _IGP0707.jpg (433.51 KiB) Viewed 26339 times
- _IGP0706.jpg (411.22 KiB) Viewed 26339 times
- _IGP0710.jpg (352.94 KiB) Viewed 26339 times
The bonnet and boot lid still need a final flatting and clearcoat, and the roof still needs a bit more fettling before it gets a top coat.
Posted: May 28th, 2013, 11:18 am
by Will01
That does look very nice, i like the colour scheme.
The white engine bay is a great idea to catch (highlight) any leaks quickly but it will be a nightmare to keep clean.
The wheels look great on the car very nicely suited, keep up the good work not too far away now. That is going to be great fun to drive
Posted: May 28th, 2013, 9:10 pm
by Urbancamo
Classic "Olio Fiat"-color theme?
I like it. Especially the wheels are almost like designed to this car.
Tommi
Posted: June 2nd, 2013, 10:40 pm
by Simon
