Sylva Leader 1800 TC
Posted: January 4th, 2010, 10:48 pm
by matt36
Hi,happy new year!
Here is my Sylva Leader that i saved from being scrapped! A garage offered it to me as a non runner because he knew i was into Fiat TCs.
I bought it after viewing it on the back of a truck (came via me to the scrapyard). It was delivered to my home that day and i was delighted to find it was fitted with
Guy Croft engine no.146! Apparently built early 90s.1756cc.
I also discovered it was chassis number 001,built in 1984 by Sylva founder Jeremy Phillips
My car mid 80s (driver Jeremy Phillips)
After little work it was running and MOTd....then came the light restoration
Complete front modified with custom lights and lots of fibreglass
Fiat Coupe rear lights
Everthing was done by myself with basic tools including respray with electric HVLP spray gun(more commonly used for wood fence treatment!)
After a few runs i decided to add a pair of Weber 45s and get it set up on a rolling road.
FRU Rolling Road.jpg (35 KiB) Viewed 8866 times
Unsure on the spec of the engine but it has 275 exhaust cam and 290 inlet with 10.5mm lift.
Facet SilverTop fuel pump
After a few hours on the rollers the final settings were as follows:
Weber 45 DCOEs
36MM Choke
135 Main
190 Air
Ignition timing 35 degrees at 4000rpm.
Final power run 119 Bhp at the wheels at 7000rpm
Fun doesn't have to cost thousands!
Re: Sylva Leader 1800 TC
Posted: January 4th, 2010, 11:41 pm
by miro-1980
Great car , and with interesting history !
(001 chassis and # 146 GC engine)
Glad you saved it .
More action pictures will be viewed with pleasure.
PS : That has to be worth thousands now !
Posted: January 7th, 2010, 7:25 pm
by matt36
Thanks for the comments, I will get some better quality pictures up soon.
Matt
