Wire ringing the block.
dafnos
guy hi!
i'm thinking to fit wire rings to my 130 tc among with racing gasket and bolts.
so after some search i found out these groove dimensions : 1.3 wide and 1.3 deep but it's not says what dia. of wire to use and what bore to groove.
can you help here?
is there any other wire fiting settings and dimensions that i can use?
here some photos that may help...
can you help here?
- the grooves....
- ringgr.jpg (15.07 KiB) Viewed 8392 times
- the wires...
- cringc2.jpg (13.46 KiB) Viewed 8392 times
bugarMK
ringed blok
Hi My Isky tool make growe 1,2mm I use 1,2mm wire but ringland are deep 0,8 becouse wire must be cc 0,3-0,4mm from top of blok end wire make extra presure in gaket...
bugarMK
wired blok
Yesterday I look my tools Wire is 1,o5mm end knife is same end the ring must be min 0,3 in - wire must be + 0,3 to 0,4 mm from top of block...
Hi
So you use 'standoff' of 0.3mm? (height of wire above block).
What wire do Isky recommmend with that? Steel/copper? Where does the wire sit in relation to the gasket with the Isky tool? Under the centre of the fire ring or outside it? What wire end-joint method do you use?
I do this op but it is not as easy to get it work as some people think, especially with very hard modern gaskets; Get it wrong and the head will not sit down and the coolant galleries will leak.
I know that English is not easy for you, just do your best, I will edit if you have any problems.
bugarMK
ringed blok
I buy tool 1994 , I have problems whit gasket - becouse thet time wos embargo whit greece- border wos close end benzin from pump never have octans whot I need I use octan busters..".end for pour gasolin not help golden gasket"... I look in some american magazins for ringed bloks.... end my frend buy tool for me in States, after thet I have not gasket falure ? or I look for some chambermods,racing gasolin end mix whit super to have from one galon 2 or 3 -not many sponzors in thet times industry end naw is sheet.....
I use copper wire whot pres gasket on metal I use only goetze, price is cheep end I use 2-3 times whit no problem
Regard Sime
Regard Sime
bugarMK
