Oil pump flow rate
Robert
Oil pump flow rate
Post by Robert »
Do you know the flow rate of an oil pump of the TC engine (Montecarlo pump) ?
Thank you,
Robert
GC_131
Re: Oil pump flow rate
Sorry, I have no data OE or otherwise.
cos
Post by cos »
the 130 abarth rotors according to Pace who had a look at them flow 28l/min per 1000 pump rpm. The gears measured 34mm od 40mm wide.
Thanks Cos, same gears as the MonteCarlo.
If anyone fancies having a go at working it out here are the fundamentals. Comparison with Pace assessment welcome.
http://www.zenithpumps.com/applications/vol.htm
Robert
Post by Robert »
Hello,
Thank you for the value. Do you know the ratio between the pump rev and the engine rev ? Because I don't think it is 28l/mn per 1000 rpm of the engine (182 l /mn @ 6500rpm !).
Robert
GC_131
The pump goes at half crank speed.
I just counted the teeth on the driven gear and aux driveshaft (14 both)
