i have a Fiat x19 1500cc 8 valve engine with a high lift cam, ported and gas flowed head, bigger in let valves and a free flow exhaust pipe. the carbs i am going to use are a set of dellorto dhla 40 what i would like to know is
1) what size jets should i be looking at to start with
2) what size chokes should i use
mark
DELLORTO dhla basic setup
mark220475
If you already have the DHLA 40s please first list sizes of what you have already in them:
4 x chokes (will be 28-34mm)
4 x emulsion tubes
4 x main jets
4 x air correctors
4 x idle jets
4 x pump jets
2 x float needle valve
Once I see what you have there I'll advise the setup. If you don't have them yet, are you buying new?
4 x emulsion tubes
4 x main jets
4 x air correctors
4 x idle jets
4 x pump jets
Dynodave
