Increased Valve Seat Internal Diameter on 128
Posted: January 11th, 2008, 12:09 am
Hi Guy!
Happy new Year to You - Nice to see the site up and running again.
I am currently building a 128 1290cc race engine for an "amateur" race series - featuring old italian cars.
Engine specs:
128 1290cc engine
Compression 10:1
Cam steel billet 284`/ 10.5mm true lift / 3.5 mm TDC / 106` Lobe separation
2 * 40 DHLA - 32 chokes
4-2-1 exhaust manifold
32 mm exhaust valves
36.2 mm intake valves
Intake port taken from 25.5 mm to 32 at port face tapering down to 28 at port venturi. Material removed from port sides and roof only at venturi. SSR rounded off and Valve "bowl" enlarged.
Exhaust port now 27.5mm from valve throat and out.
Intake valve seat internal diameter 30.0 mm
Exhaust valve seat internal diameter 27.5 mm
A valve size of 36.2 mm, plus an increased port size, and bigger cam makes me consider to grind out the inlet valve seat ID to 32.5 mm. This to aid flow at higher valve lifts. For the exhaust port (32mm valve) I consider to bore out the seats to 29 mm and follow that diameter all the way out.
Is this a good idea?
Any other considerations regarding this engine greatly appreciated.
Best regards
Remi Lovhoiden.
Some pics of car and porting work progress:
Car now stripped ready for a little paint, fitment of Lexan windows, and a roll cage
Marking out initial port face size with felt pen using old 128 exhaust valve.
Intake ports roughed out to approximate sizes - now for finishong off with sanding rolls
Just moved to new garage some bits still missing. 5-56 and a carbide burr goes a long way. 128 exhaust valve (31mm), A112 Abarth intake valve (29mm) and coin (27mm) makes excellent measuring tools...... DHLA awaiting rebuild in background
Enlarging the valve "bowl" area and short side radius
Intake ports more or less ready.. no work to exhaust port when picture taken
DHLA manifolds ported out to 31.5mm to match to head face
Engine specs:
128 1290cc engine
Compression 10:1
Best regards
Remi Lovhoiden.
