Darrian T90 owned by Colin Haggett
Colin Haggett
Post by Colin Haggett »
This is my Darrian T90, It was purchased or built in 1995 from Tim duffee of Darrian Cars in Llangybi, Wales.
Darrian T90 at a wet Longcross
Darrian T90 at Longcross.jpg (174.39 KiB) Viewed 14301 times
Darrian T90
Colin Haggett
Darrian T90 at Tim Dufee's workshop
When first built it was fitted with a Guy Croft 8 Valve engine similar to case history No 5 in Guy's brillant Workshop manual using Weber Alpha fuel injection and four direct coils. This was mated to a Hewland mk9 five speed transaxle.
Bare tub of my Darrian T90 showing how the car is built around the rollcage.
Tub 1.jpg (101.92 KiB) Viewed 14297 times
As you can see Guy Croft engine fitted to Hewland 5 speed transaxle. Plus you can see Stack dash unit.
Darrian Cars workshop 1.jpg (219.27 KiB) Viewed 14298 times
Darrian T90
Colin Haggett
Darrian T90 with 16 valve engine fitted.
Some more Photos of my Darrian T90. The spec has changed a lot, Now fitted with 16 valve engine which is dry sumped and mated to Hewland FGC 5 speed transaxle.
Inside photo showing Sack display and quick release steering wheel.
Inside small.jpg (25.65 KiB) Viewed 14291 times
Engine bay with 16 valve engine still fitted with Weber Alpha injection.
Darrian T90
Rich Ellingham
Post by Rich Ellingham »
Whats sort or output/spec is the engine. (16v)
Rich
book 38
Colin Haggett
Darrian T90 Engine photos
Some engine photos
New dry sump tank from A.H.Fabrications. Fixed problem of oil being pumped into catch tank on long stages.
Darrian engine.jpg (37.64 KiB) Viewed 14279 times
Engine with Hewland gearbox in the background.
Engine out.jpg (30.46 KiB) Viewed 14280 times
Engine out showing Guy Croft light weight flywheel fitted with AP twin plate paddle clutch. Also you will notice I have moved the coil pack away from the exhaust.
Engine 2.jpg (31.13 KiB) Viewed 14282 times
Darrian T90
