Effect of induction system on ideal ignition timing?
Posted: October 11th, 2007, 10:11 pm
Unfortunately due to time restrictions (in order to compete on Wales Rally GB this year), I've had to shelve my plans to rebuild my ex-works Group A Skoda 136 engine, and instead have bought a running engine from someone. This is on DTA management and Weber Alpha throttle bodies, which are not allowed in Group A, so I will have (unfortunately) to re-fit the original MPi inlet manifold and single throttle body. While I realise this will probably have an effect on the power output of the engine, while re-mapping I was wondering if you had any ideas if the ignition advance map would need to change to suit the new setup? i.e. would it be better to reduce the advance to be on the safe side and get it totally re-mapped?
Do you have any experience of this sort of thing (although I realise it would probably be the reverse, taking a single-throttle-body manifold and then replacing it with individual throttle bodies)?
