Fiat 131 gearbox help
hgk
Does any one now.. if there is a difference between Fiat 131 1600 gear box year 1976 and a 131 2000tc year 1980.
HGK / Sweden
hgk
Hi guy.
My box are not a tc but an ordinary 1600 but it have the exact same ratios as the abarth gearbox. that confuse me...
1 3,612
2 2,045
3 1,357
4 1
5 0,870
The diameter is a littel different
my 1600 box 215mm diameter.
Abarth box 230mm
I just found an allmost new agenta 2000tc year 85 gearbox for no money at all, 2000km that why I started to look this up. But why change if they are the same.
1 3,612
2 2,045
3 1,357
4 1
5 0,870
Abarth box 230mm
HGK / Sweden
TR-Spider
hgk
Just found out this usal information about the gearbox difference.
Argenta and 131 racing have abarth extension and solid aluminium casing with no steel plate at the bottom. The other gearbox, has a ribbed casing and a steel plate at the bottom.
Also the gearbox should have fixed rear nut for the driveshaft, the 132 had a floating nut.
HGK / Sweden
