I have recently found different results when flow testing the same two heads one stock and the other modified by myself using two different size bore adapters.
My stock head on a 100mm and a 104mm bore adapter was 172 on both ?
My modified head with larger valves was 195 on the 100mm and only 183 on the larger 104mm adapter ?
The gains are easier to see and look much more impressive using the 100mm bore adapter.
Now i wonder what the gains really are ? The engines true bore is also 100mm.
Very odd whats happening ?
Flow testing
SirYun
djaychela
superbike
Before and after testing should all be done on the same size bore right for repeatable results !
It is weird and somone suggested it may be something to do with pressure recovery and that the air is clinging more tightly to the 100mm bore than the 104mm bore. The valves on this head are so big there just short of touching the 100mm bore its self . Feel free to post follow ups
SirYun
coanda effect|?
air is a fairly odd entity it seems.
the air could be sticking to the surface (it seems similar to coanda effect... maybe) thus guiding it along the cylinder wall
thus the shrouding of the valve might actualy lessen the enegry loss by expansion.
this is pure speculation..
but it is very interesting.
I would suggest a plexi glass/windowed bore adapter a strobe light and a fog source (darin morgan suggested dryice in a large softdrink container).
it might give you some idea where the air is actualy going
Joost M. Riphagen
