I am starting to collect parts to build a 1756 for Historic racing. I have acqired a block to rebuild and I am aiming for something around 11.0 compression running on 98 Octane and very robust. I am also looking at acquiring a head to build. What would the forum suggest would be the best to try and aquire? The engine will most run a single carb. There is currently a good 1980 Lancia Beta , Type 4372281, Inlet 42mm, exhaust 36 mm available. Will this be too hard to get the compression up being a 2 litre, or are the valves too big/small.
My questions are basic but having read these forums I have learnt so much. Thank you all !! Most importantly with flow, ie the power is in the head... everything is related, so I am looking to get as much info as I can and do this once and enjoy the process.
1756 Head. Which One?
helebah
Fiat CC
