samo
Post by samo »
I have been bolting odd bits and peaces to the engine. I know it all seem a slow motion process but belive me it takes a loong time for me because I have to hand pick each and every bolt from a big box of bolts that are all mixed up and even the smallest component has been dismantled as far as possible. Even the distributor has been taken to bits, sandblasted, eloxated, new bearing, seal, oring... all in all probably a days work for a small component.
Old and renewed distributor
06052011632 (Medium).jpg (82.84 KiB) Viewed 21621 times
The bits are pileing up...
09052011636 (Medium).jpg (92.38 KiB) Viewed 21621 times
Limited edition #317
tricky
Post by tricky »
Samo, most of the people on here know how much time goes into reworking one componant because we do it too and can appreciate it, thats why we read projects like this - I know thats why I do.
Good job, I especially like the zinc gold bits very professional looking.
Twice as many valves
samo
Post by samo »
Haven't had much time to keep things up to date.
Since my last report I had a bit of an issue with one of the bolts for the intake manifold which striped the thread from the head. And naturally it was the bolt hole nuber 2 which is not a blind hole but goes straight trough the head to the oil return channel. So the belts and the intake cambox had to come off for me to be able to block the channel and avoid getting metal particles into it when I fix it. If I haden't used a Spesso gasket that costs a it would have been easier to take the head off I guess...
So after this annoying setback fixed the engine is now almost finished just a few bolt on pices are missing like sensors, sparkplugs etc...
I am now waiting for my mechanic to clear up a car lift for me so I can finish the build and install the engine. While waiting I am trying to take care of some of the less glamorous jobs like re-newing the shock absorbers, painting the springs...
BTW does anyone know the clolour code of the blue colour Lancia used on their shock absorbers originally?
Shocks and springs sandblasted and electrophosporic coat applied-
31052011678 (Medium).jpg (67.9 KiB) Viewed 21538 times
Headliner re-trimmed with alcantara.
05052011624 (Medium).jpg (56.86 KiB) Viewed 21538 times
samo
Post by samo »
Keeping busy even in the worst heat wave we have at the moment.
Shock avbsorbers, reneved, stiffened shortened and painted.
DSC04859 (Medium).JPG (95.43 KiB) Viewed 21483 times
Final cehcks and preparation for the heart transplant.
DSC04838 (Medium).JPG (59.26 KiB) Viewed 21483 times
Engine inside. Happy times for me :)
DSC04846 (Medium).JPG (88.4 KiB) Viewed 21483 times
LanciaNut69
Post by LanciaNut69 »
Samo,
Just read through the entire topic - fantastic work. I really enjoyed the time of building rather than stripping. Your quality of work is excellent and I look forward to the next update.
Darren
__________
Book #435
samo
Post by samo »
An update after a loooooong time. Don't worry I have been hard at work.
The body worki is coming along nicely.
18082011784 (Medium).jpg (47.96 KiB) Viewed 21381 times
I was lucky to get NEW injectors for a really reasonable price as the old ones were damaged by the "cleaning".
07092011803 (Medium).jpg (65.59 KiB) Viewed 21381 times
The engine loom installed, most of the pipework done and one headlight.
10092011812 (Medium).jpg (76.42 KiB) Viewed 21381 times
samo
Post by samo »
Working hard lately. Finished installing the:
-side glass, runners, locks etc.
-side indicators
-few bits of trim
-front & rear driveshafts
-front anti-roll bar
-rear boot, rear wiper motor, licence plate assembly
-left front light
-vacuum hoses for the air circulation control that I forgot to install
-finished installing the engine (it was leaning about 1cm because I installed the gearbox mounting 180° wrong way)
-rear right shockabsorber (thanks to Guy aka. infectus-guy for the donated plastic spring spacer)
-leak tested the intercooler, straightened the cooling fins, cleaned and painted....
Enigine installed & engine mounting fixed.
21092011828 (Medium).jpg (74.88 KiB) Viewed 21355 times
Rear driveshafts installed and rear-arb hooked up.
07102011851 (Medium).jpg (54.38 KiB) Viewed 21355 times
Front driveshafts & front ARB installed.
10102011868 (Medium).jpg (56.1 KiB) Viewed 21355 times
Intercooler tarted up.
27092011838 (Medium).jpg (53.59 KiB) Viewed 21355 times
Side windows and indicators.
10102011871 (Medium).jpg (49.24 KiB) Viewed 21355 times
Rear licence plate assembyl & wiper motor installed and wired.
10102011872 (Medium).jpg (47.79 KiB) Viewed 21355 times
Your photos get darker and darker Samo.
Retake maybe?
samo
Post by samo »
I am sorry about the poor picture quality.
More or less when I am done working I am just too tired to focus on the pictures and I just snap a few pics with my phone... Will try to take the camera with me next time.
samo
Post by samo »
First signs of life.
At this time still fixing the electrical installation. The engine has still not been turned over because i am still missing some bits&pices.
All red, very italian :)
13102011880 (Small).jpg (54.63 KiB) Viewed 21325 times
Never mind the fact i am an electrical engineer I still mixed up the wires for the lights.
13102011879 (Small).jpg (53.18 KiB) Viewed 21325 times
Crack tested the welded up exhaust manifold. And it showed some new hairline cracks near the weld... Still not sure about what to do about this.
16102011883 (Small).jpg (52.18 KiB) Viewed 21325 times
Fingers
Post by Fingers »
Hi Samo, mine was cracked too when I removed it, I talked to the welder where I work (Air New Zealand Engineering) he really knows his stuff, and apparently cast iron doesn't really like being welded, it will crack during welding and will be more likely to crack again after welding. So I found a new one from a good seller on e bay Germany, if you search for Delta integrale you're bound to find one on there. Hope this helps.
Or you could just live with it, but with the quality of the rest of your work, I wouldn't think you'd be happy with that.
Book # 34
There are methods to weld cast iron. Most welders would put the work piece in an oven, heat it until glowing red, do their welding and put it back in the oven. After that, they slowly cool the oven down to room temperature. That way heat and casting stresses will be relieved during welding and cooling off afterwards. Whether this is cheaper than buying a manifold second hand, I don't know. Buying one from someone you don't know that doesn't have a good reputation, is always a risk. Someone can be selling one with the best intentions, but that's just as cracked as the one you're replacing.
samo
Post by samo »
This manifold has been preheated, welded and cooled in an owen etc. But I don't know if the crack was there before or not.
I know of the company Fingers was talking about. My hat is off to them only the best stuff. And the are selling NEW OE manifolds so they should be crack free.
Front brakes assembled.
25102011913 (Small).jpg (58.54 KiB) Viewed 21488 times
One rear brake assembled.
22102011903 (Small).jpg (60.48 KiB) Viewed 21488 times
And one rear brake disaster...
22102011904 (Small).jpg (49.92 KiB) Viewed 21488 times
samo
Post by samo »
Keeping busy...
In the past days I have finished the rear end drive gear. Installed the rear strut bar and the rear diff subframe reinforcement and stabilisation bar which are suppose to make the handeling more predictable.
Also I have dismanteled the propshaft, had it sandblasted and electro cataforically painted (not sure of the right term). I have inspected the bearings... will be putting it back together as soon as I get the proper M16 nuts.
Prop shaft disassembled and cleaned.
DSC04934 (Medium).JPG (83.92 KiB) Viewed 21459 times
Propshaft sandblasted and painted.
DSC04944 (Medium).JPG (60.69 KiB) Viewed 21459 times
It's all in the details (rear wiper also sandblasted & painted).
DSC04947 (Medium).JPG (48.18 KiB) Viewed 21459 times
Very expencive clothes rack. :)
DSC04938 (Medium).JPG (79.31 KiB) Viewed 21459 times
Rear end finally finished!
05112011924 (Medium).jpg (67.27 KiB) Viewed 21459 times
Nobby
Post by Nobby »
I'm loving this thread. It would be a dream to do something like this, especially on something like an integrale.
What on earth happened to the rear caliper? Is that a large chunk missing from the top where the flexi pipe screws into?
Chris Burgess
GC 01
