Lada 2105 / January 29th update: icetrack driving
Walezy
Re: Lada 2105 / Engine building / Diff assembly
Very good solution to the coolant pipe that leaks on the flange is to cut it about 5cm away from the flange then bend it a bit to take it away from the block and fit a bit of rubber or silicone hose to connect it back. THis solves the problem with leaks as you do not bend or move the pipe flange anymore. Did that couple of times in my TC engines.
Book#378
Very nice intakes indeed.
What airbox/filter set up did you decide upon?
ah keep us in suspense!but i'll tell you more when i get there!
look forward to photos and results.
Some day I'll get around to installing full radius pipes and nice tall box filters on my DRLAs.
That looks like you will be hosting an entire Big-Band under your hood. Very impressive.
Abarthnorway - Remi L
Hi Tommi!
Cool car with really nice setup!!
Keep us informed on the developments on the carbs.
What choke size and jets are You planning to run??
Good luck!
Remi Lovhoiden
Good luck!
Remi Lovhoiden
GC_45
Persistence pays off! I wonder how it will do on the dyno once you've fixed the idle mixture.
