Ford Drag Race engine development
Maki
Re: Ford Drag Race engine development
Post by Maki »
Guy Croft wrote: Do we have a picture of the car this is going in?
Here it is...
RST ZVH
Maki
Post by Maki »
Some progress. Most of the port enlargement was done by cutting out metal from the splitter and reshaping the SSR.
Also I've matched the inlet manifold holes with the head. Could have opened the head more, but didn't see the point as the holes in the manifold will be smaller anyway.
Have some questions about the throttle body. How to count what size is optimal?. The holes in the head are 48*31. The holes between two pieces of the manifold are 43 mm. The hole where the TB is mounted is 55 mm.( but the throat can be cut away and the TB could be mounted closer to the plenum).
RST ZVH
Maki
Post by Maki »
done
P.S. will be using 52 mm TB.
RST ZVH
Maki
Post by Maki »
Hello Everybody, I had pleasure to use your help with my project, now it is up and running. I've improved my personal record from 12,27 to 12,13 this year, with the new head, IM and bigger injectors. Other then that stayed the same. Did't raise the boost , didn't adjust the map. Your views on this would be much appreciated. I'm maping it my self, and I think it could be taken further but I'm afraid to ruine the engine. At the moment CR is 7.5:1, fueling is 12:1. Boost pikes to 1,5 and drops with RPMs to 1,2... Ignition at full boost is no more then 12. I know how experienced you are. Could you give me a hint how far it is save to take it? I was thinking about 16 ignition and maybe 1,7 bar which obviously will drop to 1,4 with RPMs.
Here's how it looks today
RST ZVH
Sorry Maki but until further notice this section is closed except to those members who have my new book & put the number in their signature line.
You can open a new thread somewhere else if you want,
Maki
Post by Maki »
Guy Croft wrote:Sorry Maki but until further notice this section is closed except to those members who have my new book & put the number in their signature line.
Only now I have read your motives for that. Fair enough. Keep it real and don't give up. Thanks for everything :) Wish you wrote a book on ford engines :)
RST ZVH
