Re: Lancia S3 Thema Turbo 16v unusual valve sizes
Posted: February 15th, 2008, 3:12 pm
Guy; thanks for a superb answer and enjoyable read! I am sure so many others will benefit from this knowledge. You were correct with all of your assumptions! I will definitely do one step at a time as you suggest from now on until this problem is resolved.
Regarding my ‘soggy’ bottom: I feel it must be as you suggest an ‘exhaust gas problem’ relating to the exhaust cam. I am aware of people with 16v Integrales that use the Tipo inlet cams and are very happy with the characteristics.
In fact if any one reading this has a Dyno graph of an Integrale 16v before and after the Tipo cam modification that would really help at this stage.
Guy, on a previous post: phpBB3/viewtopic.php?f=13&t=373&p=1758#p1758 you mentioned this regarding the use of the Tipo inlet camshaft:
“The increase in lift at tdc is very modest - and remembering that my suggestion was to change the inlet cam only and retain the std turbo ex cam, this is not going to have any noticeable effect on idle - and pickup from idle. The reality is that we have not increased the overlap event to any real extent because the ex phase is unaltered… However the peak lift and lift integral (area under the cam curve) is quite a bit more - … The overall effect will be more torque everywhere and the rpm at which peak power is developed will be a bit higher to because the cylinder is filling more effectively - in other words the engine is 'breathing' better…This does presuppose that the ex valve, port and manifold can cope with the increased massflow of ex gas, without getting into a serious pumping loss or backpressure problem which I can tell you on the 8v and 16v TC units it certainly can, either in standard trim or ported/modified.”
My Tipo inlet cam timing (as requested):
Inlet opens: 1 deg BTDC
Inlet closes: 45 deg ABDC (226 duration) 10.15mm lift
My previous Thema S3 Turbo Inlet Cam (below):
Inlet opens: 0 deg BTDC
Inlet closes: 43 deg ABDC (223 duration) 8.6mm lift
As mentioned before the exhaust cam is identical (43-0), 8.6mm lift.
It seems my Tipo inlet and Thema exhaust cam is not a good formula.I now need to choose 1 of 4 possible solutions to solve this reverse flow, poor purging/ scavenging at low RPMs. I have placed them below in my order of preference:
1. To use a new Evo 1 Integrale exhaust cam (as I have one) but only if it were to achieve similar results to option 3 (below). Guy would this work? I have searched and can not find the 1992 Integrale Evo 1 exhaust camshaft data anywhere. If anyone reading has then please post it up.
2. Return to original cam setup (as suggested). This is probably best.
3. Modify current setup by advancing exhaust from 111.5 BTDC to 108 or 106 degrees, opening later and closing later (need dti, protractor etc to do this). As suggested this may improve purging and cross scavenging.
4. Return to old turbo (not an option I’d like to consider at this stage).
What I need to know is what would the likely outcomes be for each solution and best for a road car?
Thanks again!
Thanks again!
