Fiat 125s in South Africa
Rishal
Re: Fiat 125s in South Africa
Thanks Guys,
Yes limited resources is always the problem. Cheap tools, definitely agree with you, they always break.
I guess I just got lucky this time. I do have a torque wrench, but also a cheap one. Will need to upgrade before doing this engine.
Rishal
Rishal
Rishal
My Twincam
- 03072009(001) (800x600).jpg (155.78 KiB) Viewed 22655 times
Rishal
All in order, starts on the turn and sounds sweet.
Why did you choose that filter to be outside the filter housing? I'm fairly certain that the proper filter, inside the housing, would have at least the same surface area and look a lot less "boy racer" than this.
Good to hear you have a running engine in your car. Is it hooked up to the wheels yet?
Rishal
Yes it is hooked up to the wheels with a 131 2000 box. Feels great while testing.
That filter was just for the looks. Will be upgrading it soon.
Rishal.
Rishal.
Good progress there Rishal. Well done.
Can you get a good K&N round filter for that original filter housing?
PhilA
Hello Rishal
I had a 1970 125 same colour as yours. The body and interior was sold years ago, but I kept the motor and running gear, and those parts are now well on the way to becoming a Lotus 7 type sportscar.
But I kept my factory manual, called Fiat 125/125 Special Shop Manual, so if there are any problems or questions you may need help with, especially relating to the layout or routing or wiring of anything just ask.
Someone commented on the gearbox being a 4 or 5 speed. The 125S had a 5 speed.
Rishal
Thanks guys,
Yes there is a K&N filter that is available. I also have a copy of the workshop manual.
I used the wiring diagram to do my wiring, but difficult with the Italian color codes.
From my knowledge the 125 has a four speed box and 125s/125 special has a five speed box.
Luck me, was able to get my hands on a 131 2000 box. Had to cut the tunnel because gear lever position moved forward
and had to shorten the prop shaft.
Rishal.
Rishal.
Rishal
Rishal
Rishal
Hi guys,
Can someone tell me what flywheel this is. It weighs around 14 pounds. I would like to know if its a stock item or if it has been lightened.
Can I use this flywheel on my stock 2L engine as is?
Rishal
Rishal
Hi Rishal!
Does that flywheel have 12 mm bolt holes (pretty hard to see in picture)?
If it has, it has definately been lightened. 2 litre stock flywheel weighs about 18 lbs or 8.2 kilograms. And it definately looks like it has been lightened. Radius on the outer edge seems to be pretty good, but I don't like that almost 90 degree bend in inner region. More wiser guys can give more detailed information.
-T
-T
Rishal
Yes it has 12mm bolts. So if it has been lightened, can i balanace it and put it on? Some say it needs to be balanced with
the crankshaft, but that means stripping the engine.
I don't like that FW at all. See photos below.
They are prone to fracture when machined like that!
An old FW should be crack-tested and checked for 0.020" step height between friction face and clutch mounting diameter and checked for runout between friction face region and crank mounting flange (which should be no more than 0.004" at extreme diameter). if the friction face is badly worn or has heat-cracking it should be reground and the step remachined nice and true. Then it mUST be balanced with crank.
Given the state of yours I recommend you try and find another.
- IMG-20120621-00065%20(800x600).jpg (99.26 KiB) Viewed 22566 times
- IMG-20120621-00066%20(800x600).jpg (101.16 KiB) Viewed 22566 times
- done right it should look like this
- Lightened Fiat 2 liter FW_01.jpg (457.67 KiB) Viewed 22566 times
- here the friction face grinding op and step machining are done, note CLEAN condition - the old thing should be beadblasted and crack-tested before anything else
- Reground Fiat 2 liter FW.jpg (452.19 KiB) Viewed 22566 times
- get this wrong and the clutch won't have enough clamping force. Some engines don't use a step but these do...
- 20 thou step.jpg (440.65 KiB) Viewed 22566 times
- flywheels can crack, yes. And if they do - they are likely to cause serious damage and/or injury. When a FW bursts - or a clutch - the crank stops dead because the broken bits wedge against the bellhousing and the cams keep turning (for an instant anyway) so the cambelt usually snaps - ramming the valves thru the pistons etc etc. Definitely a scenario to AVOID!
- PH 00.181 prep (3).jpg (116.37 KiB) Viewed 22566 times
