Fiat 131 Abarth Stradale Overhaul
RedLexus
Re: Fiat 131 Abarth Stradale Overhaul
Post by RedLexus »
So long since I updated this! Too long in fact . After spending literally hours on the 'phone , to absolutely everyone I could think of who could possibly have any knowledge of the Abarth engine...I drew a blank . So upsetting , as I hate leaving a job not "right" . Sadly due to other commitments by the owner , I had to refit the old , incorrect drive gear , so he could take the car away .
Until....an absolute outstanding gentleman , familiar to some members here , Mr. Mick Wood stepped in and supplied the correct gear . What a true Abarth ebthusiast . I cannot thank you enough Mick , I hope some day if you're over here in Ireland I can do you a favour too .
Anyway , back to the mill....
By this stage the car was running , albeit with the slight rattle from the Distributor (pre Mick Wood intervention) . On driving the car however , I had an intermittent , louder rattle , when it was there it would be at a steady beat , then could disapear for miles . It seemed most common on overrun . Much headscratching later and I removed the fuel pick up pipe from the petrol tank .
As you can see , the gauze was sucking itself in.. and coupled with the pulsing effect of the fuel pump , the (steel) pick up pipe was tapping the side of the fuel tank . A real peculiar one . I removed the gauze completely , fitted an Inline filter just before the fuel pump , and gently bent the pick up pipe away from the side of the tank .
Ford Sigma KA. GC_43
RedLexus
Post by RedLexus »
Another thing that puzzled/worried me , was the noise from the LSD! while driving in circles , it really clunks and bangs...or well it did . After a few hundred miles it has "softened" up a bit , still locking nicely under load , but not rattling as much whilst turning .
After all that interesting work was done , it was back to more mundane things like checking and tidying the wiring , getting all lights working , I added a 2nd , stronger Earth strap for the battery and basically made it a properly legal and useable car for the road . My Dad is a better man with carbs than me , so he played with the settings of the Webers , and got it ticking over and responding nicely .
Look out for the next instalment in a couple of weeks when I have this lovely car back to properly set up the chassis , Fit a custom made ITG Foam air box , and play with the Carb jetting some more .
The owner also dug deep and restored the car to its full spendour , tidying up a few stone chips and cracks in the GRP panels . Bear in mind this is a classic that really gets driven , and driven well .
here it is in all it's glory with 2 brothers-in-arms.
Post by miro-1980 »
Redlexus,
I am rebuilding the Abarth suspension. One of key parts I am missing are the springs ( front and rear) as well as all the parts that go on top of the struts to fix them to the chassis.
Any hep advise you could offer?
RedLexus
Post by RedLexus »
I think the fronts are very similar to 200TCs , the rear I honestly don't know .I've never worked on anything other than Abarths! I'll have a look around and come back to you .
Post by miro-1980 »
Sorry for ignorance but what is 200 TC?
RedLexus
Post by RedLexus »
Sorry for my ignorance , I meant 2000 TC! the 131 2.0 Twin Cam.
