Ford escort RS turbo CVH head porting
Maki
Post by Maki »
Guy Croft wrote:You first need to read GC V/W article about 'matching' in head prep.
Thanks I read it, but there is nothing about the theory that the downstream step in the exhaust port is left to stop gases traveling back to the cilinder as they hit the turbo f.e.
What view do you have on this?
RST ZVH
Re: step on ex port.
It seems to be true that having the header bigger than the port works both in software simulation and in practice. I'm afraid I do not know the exact reason.
Maki
Post by Maki »
Yesterday I was about to finish my porting job. Made a fork for that with 80 grid paper but discovered that the fork is useless on the bends. It is possible to grind only flat parts with it. How do I finish parts on the bends? by hand? Spent 1.5 hour rubbing it by hand but got nowhere near the finish I was hoping
RST ZVH
Maki, hi
no, a split fork tool will only finish, it won't give you a high enough metal removal rate to use for smoothing straight after removla burrs.
However, the ATA Ataband at 50 or 80 grit will do this, and if you overhang the band over the end of the tool it copes beautifully with curvature, and there are no bends in the CVH that it will not reach.
You need to get some, that's what I use. You won't get the results I do without the same tools. I tend to go burr-Ataband-split fork. Buy maybe 2 off 15 x 25mm Ataband holders with bags of 50 and 80 grade bands and life will start to look a bit easier.
Post by sumplug »
Guy.
At what rotation speed do you use these tools?
Andy.
Anywhere 10,000 - 20,000 rpm with a Metabo variable speed die grinder and 6mm collet flexi shaft. The machine has torque feedback so you get high power even at lower speed.
Maki
Post by Maki »
Today I've bought these
Will see how they work
RST ZVH
Maki
Post by Maki »
Finished
now will take it to the shop to cut the angles for the valves,
then lap the valves in,
machine head gasket surface,
wash it and assemble.
RST ZVH
I have commenced work on the 1600 CVH at my works, see article at:
http://guy-croft.com/viewtopic.php?p=4222#4222
I am doing it step by step and trying to cover everything. I hope it will be of interest.
Maki
Post by Maki »
Hi Guy, will there be part II? Did you finish the CVH head?
RST ZVH
Yup, really, really sorry. There are a number of er, embarassing 'holes' in the GC V/W!
I will finish the CVH article before or over the Xmas break for sure, remind me by pm.
