Fiat Strada 130TC Rally prep.
Biancorally
Re: Fiat Strada 130TC Rally prep.
Post by Biancorally »
you are absolutely right, the catalyst can not work properly at this point. Why I put it there? Put the catalyst as far as possible in the exhaust system absorbs less power. To my knowledge there is not really a specific location by Regulation to position the catalyst.
The policy of the catalysts on race cars is still a mystery to me.
Daniel
GC_17
TR-Spider
Post by TR-Spider »
I am also amazed by these regulations, which are the same for the "Youngtimer" '76-'90 class.
On the other hand, when watching these cars at races I always see the catalysts glow orange, which means they are pretty much at working temperature.
Normally one does not much "cold starting" in a race car (which is why they are placed close to the engine at road cars).
Additionally it is much easier to exchange such a catalyst at the exit, so I think we can live with that.
Thomas
GC_23
Biancorally
Let me introduce the work done on weekend.
rear suspension, with bracket to screw brake caliper
new rear bearing kit with heat treated wheel stud
Brake cleaner to cleaning threads
assembly with Loctite
note bearing kit left, with ABS rotor, at right standard
the ABS rotor will enable me to subsequently place a speed sensor
wheel bearings  tightened with specified torque
nuts secured
nuts secured
this is a disc brake conversion (Strada originally fitted with drum brakes at the rear, ever)
GC_17
Thanks for your kind comments Daniel, I am very pleased this site is showcasing your work. I admire the care you have taken to produce exceptional photographs from which much can be learned and the elegant text that accompanies it all, esp given that English is not your native language.
One thing - at a glance - that bothers me a bit is the aval space for a ducted intake system - see below - and you must give consideration to that. You certainly musn't induct at rad exit air temp. Shorter trumpets and radiator shifted forward an inch or so will help. You need 1" between the rampipes and any surrounding airbox architecture.
Biancorally
thank you for your comments.
I do not intend to drive with open pipe rams. I really respect what you have already noted several times, about it, to other members, airbox is also part of the project.
I am always glad to hear your opinion.
Daniel
GC_17
Biancorally
some update, airbox, door panel and larger brake disc with twin piston caliper.
Two variants in terms of air intake.
The first variant is to place the air filter directly on the front of the box.
The second is to place a kind of extension to avoid taking heat from the radiator.
Let's say that the alternative number two is probably the best, the problem is how much the engine is swung during acceleration and braking? The junctions between box and extension cord are door seals which are very flexible.
aluminum airbox plate
airbox
airbox
airbox, door seals for extension cord
airbox extension
airbox extension
Interior trim template
right side
right side
left side
left side
LH front carbon door panel
RH front carbon door panel
competition brake disc with alu. bowl
assembled, disc and caliper
caliper clearance
caliper clearance
seen from the inside of the rim
GC_17
mitch strada
Post by mitch strada »
Great update.
Are you using solid / very stiff engine mounts as that airbox is very close to the front panel - or is it screwed to the front panel?
May cause problems as you say when the engine moves.
Perhaps you can consider removing the front panel completely and making a whole new arrangement from tubular steel - a spaceframe type arrangement
that will give you more strength and space as you can make it "bolt on" if you wish and also attach mounting points where required - if you wanted to you could remove the inner wings and spaceframe the whole front end - if you wanted to that is and if regs allow. . . .
Can you tell me more about / post a photo of the front wishbone / suspension arrangement - it looks great.
Abarthnorway - Remi L
Hi Daniel!
Extremely nice project You have going there!
I especially like the airbox arrangement - lovely.
I am following Your thread closely when I have time.
Good luck to You - nice to see someone using the 130 TC for what it was intended:-)
Best regards
Remi Lovhoiden
GC_45
Biancorally
mitch strada wrote:Great update.
Hi Mitch,
yes of course the engine mount is very stiff, perhaps even too much, as you can see from the pictures below.
A tubular construction of the front panel, so maybe next time, a lot of work to do this.
The air box is screwed to the TB's, the extension is screwed to the front panel. I build the air box as large as possible to get an inch of freedom around the ram pipes as Guy preconise.
A small update at the front brakes:
-Brake hose done
-Invert the bleed screw
-bleed the brake system
The front wishbone is made ​​of steel tube and uniball joint.
The rear is also on uniball, stock arms.
Engine mounts rubber bearings are from suspension bushings
Brake hose
Brake hose
Wishbone on uniball
Wishbone on uniball
Uniball on push rod, (stock rubber pad removed)
wishbone rear view
wishbone rear view
Shim under the steering control arm to avoid bump steer
Damper
Damper
Uniball Top Mount
Uniball Top Mount
Rear link on Uniball
Last edited by Biancorally on January 17th, 2012, 7:59 pm, edited 1 time in total.
GC_17
Biancorally
Abarthnorway - Remi L wrote:Hi Daniel!
Best regards
Remi Lovhoiden
Hi Remi,
thank you very much.
Daniel
GC_17
mitch strada
Thanks for the photos very nice work indeed.
I can t see the front antiroll bar - have you removed it?
Also are you converting it to hydraulic clutch to replace the cable?
Possibly insufficient engagement into the nylon here?
Whether yours is OK or not I post this for general info because frequently I see cases where there is not enough penetration to prevent the nut working loose under constant vibration/applied load. Most male fasteners have a region of 45 deg taper at their end which must be allowed for - the nylon must fully engage on full-form threads.
here is a photo of a 16v 124 sent to me - did not like this at all, especially in that critical location right next to the cambelt
Biancorally
Guy Croft wrote:Possibly insufficient engagement into the nylon here?
Guy, you're absolutely right I have unscrew the nut. Indeed, the nylon is just half marked, you do not miss anything, I love your meticulousness. Thank you for these precisions.
Daniel
GC_17
Biancorally
mitch strada wrote:Thanks for the photos very nice work indeed.
Mitch,
i do not use any stabilizer bar for now. If I really need a stabilizer bar, then only on the rear axle.
Yes, i convert it to hydraulic clutch. The clutch diameter is 184 mm instead of 215mm stock.
I hope the clutch system survive. The bearing is based on an aluminum plate of 10mm.
Statice it disengages well.
Dynamically not tried yet.
Daniel
hydraulic clutch
hydraulic clutch
AP clutch
AP clutch
Light flywheel
Light flywheel
GC_17
mitch strada
Thanks for the update, i look forward to your next report.
