samo
In December I have been mostly at work and couldn't really do much on the car. But still I managed to put in a few hours to finish the brakes. So after completly covering myself in brake oil 3 times the brakes are finally finished (apart from the handbrake)!
First I had a problem because the banjo bolts had a head that was too small and the copper gasket didn't seal.
Second time the brake splitter haden't had enough clearance and didn't sit flat against the brake master cylinder.
And the third time I had a brake oil shower as I found the rear brake regulator was leaking heavily because I didn't assemble it correctly!
But all in all the brakes are working now.
I also didn't want to take any chances with the gasoline tank which was cracked and welded back so I bought 2-pack tank sealer and had a go at it.
- The brake master cylinder with the bolts and splitteres that caused me many headaches.
- 191220111022 (Medium).jpg (75.7 KiB) Viewed 19009 times
- The banjo bolt with a small head distorted the seal! Didn't see that one coming...
- 171220111017 (Medium).jpg (85.69 KiB) Viewed 19009 times
- Proper banjo bolt with 2 mm bigger head.
- 191220111019 (Medium).jpg (59.41 KiB) Viewed 19009 times
- Cleaned, zync plated and painted WG valve.
- 020120121034 (Medium).jpg (38.45 KiB) Viewed 19009 times
- Dissasembled the fuel pump to clean and inspect it. No problems to report for once!
- 020120121031 (Medium).jpg (68.86 KiB) Viewed 19009 times
Limited edition #317
samo
I have to say I envy you guys doing the engines and metalwork... I am currently stuck with reattaching trim bits and I hate it. The plastic stuff allways fights you and you can only win if you brake something.
- Outer window seal. 3 hours for 2 seals.
- 070120121043 (Medium).jpg (49.73 KiB) Viewed 18980 times
- Right sill. 3 hours of heavy cursing.
- 080120121044 (Medium).jpg (67 KiB) Viewed 18980 times
- It allways amazes me when I see how much damage a single hillbilly is capable of inflicting on a single part.
- 060120121037 (Medium).jpg (69.06 KiB) Viewed 18980 times
- The proper way of doing it up. Mind you the white and black nut are the same acording to Fiat.
- 060120121039 (Medium).jpg (52.92 KiB) Viewed 18980 times
- This hoses are also the same item acording to Fiat...
- 060120121040 (Medium).jpg (49.73 KiB) Viewed 18980 times
samo
Finally a cheap solution :)
And I think a good one also!
All in all it only costed 3,5 € for a new bearing and a 0,2 € for the clip. Witouth that the thing was un-usable!
- Cooling fan bearing. Bearing is no good but it is inserted in the motor housing held secure by a ring.
- 08122011997 (Medium).jpg (90.53 KiB) Viewed 18969 times
- 2 precision cuts with an angle grinder, new bearing and clip. Job well done!
- 090120121045 (Medium).jpg (73.66 KiB) Viewed 18969 times
samo
Some progress...
- Fan assembled back together! Everything was taken apart repainted, zyncplated, renewed bearing.... almost like new.
- 120120121049 (Medium).jpg (74.44 KiB) Viewed 18955 times
- No drama here, this is actually new. Suppose to give a bit better preformance as this is an aluminium radiatro and the OE is copper.
- 120120121047 (Medium).jpg (100.35 KiB) Viewed 18955 times
rmouthaan
Hi Samo,
I have just been looking through your restoration project, thanks for the excellent write up and pictures taken.
Really well done, shows clearly the amount of work needed for an proper restoration. Keep it up, good luck!
Regards and all the best,
Remco
Remco
Regarding the aluminum radiators I have to agree.
I recently changed my old copper/bronze OE one for a light aluminum one and the difference was quite noticeable.
Okay maybe they won't last 3 decades but they are cheaper and cool faster and that is what we need.
samo
Thanks for your input I don't really get much feedback from forum mebmers here...
After 2 attemps of welding the exhaust manifold i gave up and bought a new one. No high performance parts here, just OE cast iron.
- New OE manifold.
- 190120121064 (Medium).jpg (66.19 KiB) Viewed 18527 times
"Thanks for your input I don't really get much feedback from forum members here"
Sorry Samo - I know how you feel!
Take encouragement from the number of times folk look at your photos though. I reckon most of us are in awe of what you are doing and how you are doing it.
For myself I am never quite sure what does interest people, to be honest. Sometimes I post things and imagine I'll get a big response. I rarely do!
LanciaNut69
Hi Samo,
Don't be despondent - I'm sure that many like me do read through your posts and are slightly jealous of what you are doing. It is the ultimate nut and bolt restoration and I for one look forward to your updates and pictures. Did you know that you have had nearly 11,000 views of your topic?
Keep your chin up, and carry on with the excellent work you are doing. The pictures on their own are worth a lot, just in terms of reference.
All the best
Darren
All the best
Darren
__________
Book #435
Book #435
tricky
I'm still following :-) Can't fault your work so far.
Twice as many valves
timinator
Welding cast iron exhaust manifolds is one of those repairs that takes some practice to master. It requires an arc welder, oxyacetylene welding rig, and high nickel content welding rod. You start by bolting the manifold to a rigid piece of steel (as in heavy). Grind the crack in a vee relief, and grind off all the scale that has formed in the area. Wire brush away all the trash from grinding out the vee. Heat the area around the vee until it is a glowing orange and then begin welding immediately. As soon as you stop welding apply heat again to keep the weld orange. Slowly begin moving the torch away from the weld. Take about five minutes to move the torch back far enough that the weld begins to cool. After the manifold has cooled it will need to have the mounting flange resurfaced. If the crack is surrounded by metal that has small fractures chances are that during welding you will blow holes in the manifold. You can lay another pass of weld next to the first to close these holes. If this continues to happen you might need to scrap to manifold.samo wrote:Thanks for your input I don't really get much feedback from forum mebmers here...
I have enjoyed reading about your project and apologize for not having complimented you on your good work. It is very generous of you to document the process for everyone to learn from.
Tim
samo
Thank you all. To be fair I never noticed the 10k views so I guess people are reading my thread. Thank you for the encouraging words gentelmen! I started a few threads of my restoration project because of a simple reason. It was because I was getting sick of people trying to pass off bodged up cars as properly restored so I wanted to set a bench mark of what an ordinary mortal (with only basic knowladge) can do. Of course professionals can do it better and faster.
I realise that it is simply not possible for others to be equally excited about small details as I am.
Tim thank you for your input! I have no access to proper equipment for welding cast iron. I had a friend of mine give a go at it as he is a welder by trade. I really didn't want to spend money on experimentihg with welding as the new manifold "only" costed 160 Euro (including postage and tax).
Well on to tonights tasty treats!
- New exhaust manifold joined by a re-newed turbocharger.
- 190120121068 (Medium).jpg (83.58 KiB) Viewed 18527 times
- The guy who renewed the turbo was a pro. I was impressed that he took the time to not just clean everything but also sandblast the alumium housing to make it look new!
- 190120121066 (Medium).jpg (65.87 KiB) Viewed 18527 times
- So now it looks new on both sides! I have taken the time to de-burr all the edges on the housing to minimise the chances of the housing cracking. Or at least delay the cracking.
- 190120121067 (Medium).jpg (72.35 KiB) Viewed 18527 times
- Picture shows old parts that were changed. No cheap 3 pcs chinese renewal kit. The intake backplate was warped si it was replaced by a new one. All new parts OE Garrett.
- 190120121069 (Medium).jpg (69.63 KiB) Viewed 18527 times
- Deburred all the edges on the manifold too. Hope it helps...
- 190120121074 (Large) (Medium).jpg (79.25 KiB) Viewed 18527 times
- Cleaned the mating faces of the downpipe. I used sandpaper on the side where the sealing is done metal-to-metal. On the side where a gasket is used a more coarse file
- 190120121075 (Medium).jpg (76.29 KiB) Viewed 18527 times
- Any ideas why Fiat engineers decided to use different pitch thread on this downpipe bolt. 1,5mm pitch on the longer side and 1,25 on the shorter. Good thing I noticed before cleaning the threads with a die.
- 190120121077 (Medium).jpg (75.49 KiB) Viewed 18527 times
Nobby
Samo - I too am loving your resto project. You may think that proffessionals can do a quicker or better job, but I think you're wrong. I'm very impressed at your understanding of EVERY part of your car.
RE: the downpipe thread. Hmmm... perhaps to stop from putting in the wrong way round? Does the different sized thread mean its more likely that the nut gets undo rather than the whole stud comes out? Or maybe they had a batch load left over from years passed and re-used them ;)
I really don't know. BUT you've prooved once again that you are very thorough. Well done.
Chris Burgess
GC 01
GC 01
Fine pitch on the 'metal end' into a material like the type of cast iron used on these manifolds would give greater shear strength than an ISO thread form, important especially given how short the engaged length is. There are a number of things one can do with a fastener to achieve high holding strength in a turbo 'hot-end' application - this is, I have to say, a rather basic attempt at improving the joint strength.
1NRO
Samo,
Your showing work that few can do, not common at all among professionals, not in the slightest and if you could find one capable enough the cost would be huge as the hours are long but I don't need to tell you that do I. I believe that work like yours is mostly found amongst DIYer's, you can rarely employ such care.
Keep at it, your doing a great job.
Nik
Nik
259
