Audi Quattro rebuild
4v6
Re: Audi Quattro rebuild
Post by 4v6 »
Ive had some experience of modifying these particular cylinder heads so hopefully the following contribution may be useful and appropriate to post here.
The Audi Quattro in 10 valve guise, comes in two basic types- WR and MB, the designations applying to the engine types fitted.
Intake valve sizes are 38mm with exhausts being 34mm across the engines.
Essentially the engines are almost identical but they do have some differences, namely compression ratio, dimensional differences with the conrods, big end journals, gudgeon pins and pistons being the main ones.
The cylinder heads are again essentially the same apart from the combustion chamber shapes/volumes but there are some other differences that are not readily apparent until you look inside.
The earlier WR heads appear to have an intake port that is very much better finished as standard than the later MB heads and it shows up as having a higher bare port flow than the later MB heads to the tune of around 10cfm@28" depression, the WR heads flowing ~150cfm as compared to the MB at 141cfm@28" depression.
The improvements I have found on these ports are attributable to the short side radius and the extremely intrusive guide bosses on MB heads. I have not experimented with valve seats as of yet.
The exhaust ports are as far as I can see identical and flow similar amounts, however after modification, although the bare port flows have increased by a similar percentage to the intake ports, the valve in flows dont appear to alter.
I would venture the opinion that valve sizes, seats or shapes would seem to be the limiting factor on the exhaust side, however I have not investigated this further at this point in time due to the limitations of my flowtest equipment.
Im sure Guy could offer his expert analysis regarding the above issue.
Cylinder head part number. 035 103 373 is the same base number for all 10 valve heads. A/D identifies as WR.
S8006463 (816 x 612).jpg (122.54 KiB) Viewed 6121 times
MB cylinder head intake port with intrusive guide boss. Uses 8mm stem valves.
S8002019 (816 x 612).jpg (60.26 KiB) Viewed 6121 times
WR intake port. Smaller guide boss means the guide is exposed but bare port flow is better than MB.
WRintake (816 x 612).jpg (63.5 KiB) Viewed 6121 times
Short side radius has ridges left by machining ops that degrade flow capability.
S8002027 (816 x 612).jpg (74.69 KiB) Viewed 6121 times
Bowl also has ridges and rapid changes of dimensions due to factory machine ops. Guide boss clearly in view.
S8002026 (816 x 612).jpg (74.08 KiB) Viewed 6121 times
MB type chamber shape. Also shared with naturally aspirated KV 5 cylinder Audi engine and VW Golf GTi.
S8002141 (816 x 612).jpg (143.83 KiB) Viewed 6121 times
WR combustion chamber. Hard to see but opens out farther to the periphery of the cylinder past the plug.
S8006492 (816 x 612).jpg (92.83 KiB) Viewed 6121 times
Chamber shape easier to see on this photo.<br />Flatter and further out to the cylinder wall than MB. This is actually a WN ( carburettor engined head) but essentially the same as WR.
S8006908 (816 x 612).jpg (122.2 KiB) Viewed 6121 times
Flowtest results. Blue lower line is exhaust flow and dosent change even though BPF goes up.<br />Red is stock intake and stock valve.<br />Yellow is modified port and 30 degree backcut on the intake valve giving the gain at 3 to 6mm lift. Stock valve does not exhibit this gain.<br />BPF of the intakes on the modified port at 167cfm@28&quot; depression.
BPF of the intakes on the modified port at 167cfm@28" depression.
TPE4v6 MJ-instk+mod+ex (1013 x 478).jpg (113.44 KiB) Viewed 6121 times
Tony Warren. GC #96.
Excellent synopsis - methodically presented and well illustrated/captioned, Tony, thanks!
