Volumex crank & other questions
Hi guy,
I'm just wondering if there is a difference in tightening between crank with front nut (normal 2l TC ) & crank with screw in front (like 130TC) ??
Also if the Volumex crank is different from those two mentioned above?
Many thanks
Many thanks
Nassim (Book#327)
Re: Difference between crank with nut & crank with screw
No, both should be done up to 120-130lbf ft. Those late setup with reverse thread bolt (130TC, Vx, Integrale etc) are all the same thread and same torque.
Hi Guy ,
thanks for fast reply.
you are talking about crank with - reverse - thread bolt ( i had it on my previous Vx engine ) , but what i have in my engine now is a crank with regular nut ( not reverse - the engine came as it is from a used parts dealer) thats why i'm asking . may be it is from a 2l TC 8v late engine that have different characteristics than these you mentioned (130TC,Vx,or Integral ) and thats why i dont have acceleration more than 4000 rpm ...
looking for help ...
Nassim (Book#327)
The nut was introduced on the 130TC which was launched in 1983, the Beta, 131 and 132 units were still in production so you could not ID the engine merely from that. Give the casting code numbers from the block - under the inlet manifold.
the block casting number is 828b7000 , i'm sure it is a Lancia Beta Vx engine, but the Crank does not belong to it but i'm not quit sure about that , as the block were brocken from side which is a clue to broken crank ( because the rods are Vx - nuts & not bolts if that info is right ?? )
Nassim (Book#327)
Yes, Lancia Volumex block engine code is 828B7000, I am building one here and I just checked it. The crank in this one has a reverse thread bolt as have all the Vx units I've seen (pretty sure anyhow) and the rods have nuts and bolts.
so we are sure now it isnt a Vx crank .
i got a used 130TC crank from a used abarth engine , it is good and STD size bearings , and have a reverse bolt thread.
shall i strep down the engine and replace the cranck with this one , and keep the other setup as is :
-HC pistons 11:1
-Vx
-43.5 in , 36 out valves (normal asperated heat bored and polished)
-normal asperated STD cams from 130 TC
-Vx beta carb.
or you advise to change something in this process ??
-HC pistons 11:1
-Vx
-Vx beta carb.
Nassim (Book#327)
is there any marks or printed numbers to identify any crank as Vx,130TC,or Integral ??
Nassim (Book#327)
It can't be an Integrale crank because that has a completely different nose and would not fit your unit. The only difference betw the 132/131 cranks (not entirely sure about the 130TC because I have never measured them) and the Vx is the Vx has 5mm diameter oilways on the big end journals compared with 4mm on the 131/131 series. The Int crank has 5mm as well but is not crossdrilled FWIW.
You running 11/1 CR on supercharged?
yes guy ,
thats why the engine dead, i cannot get acceleration more than 4000rpm and not much power.
i will replace the Vx with dual 45 webbers , do you think with such HC pistons will be better ??
Nassim (Book#327)
Nassim, hi
you need only 8/1CR with the Vx (more or less, I don't agree with more though some disagree, less is do-able also, I have run as low as 7.2/1). On normally aspirated you can run almost as high as you like depending on the octane of the gasoline. However I suggest a full strip of that motor - head off and pistons out because if it's been running as a supercharged unit at 11/1 there will almost certainly be chronic detonation damage to head, gasket, pistons, bores, rings etc etc. That is my guess anyhow, and certainly an engine like that struggling to get over 4000rpm sounds like it could be a detonation problem. Detonation is not something you can 'drive thru' with too high CR, it just gets worse and worse.
Thank you very much for your support.
I will strip down the engine, but not now, may be March, I don't have time for such effort right now . I will keep the car stored untill that time, and will let you know step by step .
My best regards!
My best regards!
Nassim (Book#327)
Re: Volumex crank & other questions
Hi guy,
i'm sorry for the misunderstanding that happens in the title "Volumex with very high CR pistons" .
i meant that i will fit original mondial pistons from 2.0 132 (that will give 8.5:1 CR).
the engine now is running well and healthy with STD cams (Not Vx) and original carb from 131 volumetrico (not Lancia Beta).
i will upgrade the carb to Weber 40 DCOE with the setup you gave me earlier ( i'm waiting for the parts to arrive now ) and see how it will go.
i'm not sure about how much HP it will produce .
one thing i need now is , which camshafts you recommend for this setup from your sellection ???
do you agree with smaller Vx pully to produce higher pressure ?? (just one tooth)
Nassim (Book#327)
Users browsing this forum: No registered users and 110 guests
