2L twin cam overhaul
Hi. I have a little problem with my cam housing, it seems like my gasket for the cover in the rear of the camhouse is to thin, when i tigthen the cover the cam gets stuck. If the gaskets is the problem where can i buy the proper ones, first picture is the old gasket the second one is the new and the third is two new gaskets together, i am going to use a block mounted distributor, so i want a lid or cover for my cam house where the distributor was.
- image.jpg (552.49 KiB) Viewed 8547 times
- image.jpg (597.56 KiB) Viewed 8547 times
- image.jpg (547.35 KiB) Viewed 8547 times
- image.jpg (581.19 KiB) Viewed 8547 times
- image.jpg (529.83 KiB) Viewed 8547 times
Re: 2L twin cam overhaul
You're not the only one who encountered this:
http://guy-croft.com/viewtopic.php?f=4& ... zed#p21334
GCRE can supplement the right gaskets for sure.
Thanks for the answer to my problem, much appreciated.
Best regards Håvard Mittet
Users browsing this forum: No registered users and 89 guests
