Finding age of engine
MinorTC
Post by MinorTC »
Is there any way of identifying the age (year of production) of a Fiat twin-cam engine?
Maurice,
East Kent.
Urbancamo
Re: Finding age of engine
Post by Urbancamo »
Engine code number tells you rough range of production year.
GC_25
badlyworntoy
Post by badlyworntoy »
Yes thats right,If you get a copy of Guy's first book theres some very comprehensive tables showing which numbers came from which cars and when they were produced.so simply find your engine number and compare against the data.
On the two engines I have the numbers are in different places on the block.On the earlier engine it is just above the oil filter housing and the later on its a flat just next to the left hand engine mount,not sure if they're all like that but its a good place to start cleaning rust from.
Ian
What engine is it?!
MinorTC
Post by MinorTC »
It's an (as far as I know) standard 2-litre from a 131/Mirafiori.
Engine numbers are:
132DB2A0
131 24 000
1495214
Cylinder head:
5991740
Maurice,
East Kent.
First produced 1972 ended 1985. The 2 liter 132DB coded crankcase was variously used in the RWD Fiat 132, 131, Argenta and 124 Spider models all with the same cylinder head, cams.
If you need more info please tell me why you need more and if I can help I should be happy to.
MinorTC
Post by MinorTC »
Thanks for the info, Guy - much appreciated.
Maurice,
East Kent.
Users browsing this forum: No registered users and 51 guests
