Hi Peter,
I'm going to be running std cam with a Pumaracing big valve head. Head has been skimmed - think the CR will be about 10.5/11:1. I need to measure the combustion chambers and piston recess to confirm this.
The squish height on your engine seems very small - is this important to geting good power and is it feasible to use such a small squish on an engine running std ignition? Does the tight squish height reduce detonation as long as the CR is sensible?
Modified engines & factory (OE) fuel injection
benlilly
petert
petert
