I have some peugeot sport Mahle forged pistons that have fully floating pins. (They are designed for a 1294cc 205 Rallye)
I am not using these right now. However I have been offered a set of modfied connecting rods that have been modfied to fit forged pistons. The measurement of the small ends are claimed to be 20mm.
I measured the pins on my pistons (with a digital slide) and I measure 19.98, 19.97.
I have little knowledge of the tolerance in the fitting of floating pistons. Does this sound like a good fit for my pistons. Or am I better off getting someone to machine my standard conrods to fit (which are normally a smaller interference fit)?
Christopher
Floating piston pins - Fitting of conrods
Hello Chris
those pins would be way too loose, rattle and knock the rods to pieces, you need about 0.008mm clearance for a good sliding fit rod-pin. rod bush-pin fits are a job for the expert only (ie: rod manufacturer).
Better to get some race rods made. I use only Calif based Cunningham as it happens but UK Arrows do race rods too and are a nice firm to deal with.
FWIW you are on the right lines, I'd never run press fit pins for choice.
Users browsing this forum: No registered users and 105 guests
